Mesh quality control in Paraview/Openfoam
Hello!
I created a simple channel flow case in openfoam with a step in cross section. For the mesh I created 2 blocks with different meshes at the interface between the blocks. Then I applied the "MergePatchPairs" command in blockMesh. The user manual says that blockMesh adapts the meshes somehow at the interface. Now my question: Is there any possibility to check how the mesh is really looking like? I created a slice through the domain in paraview and used the "wireframe" or "surface and edges" display mode, but the mesh looks really crazy. A collegue of mine told me that paraview would not display the real mesh properly. Thanks in advance :) Sandu69 |
Greetings Sandu69,
Yep, your colleague is right. I read your thread before going on my search about snappyHexMesh, and found what starts in this post, has the solution for you a few posts later. So your colleague is right about Paraview triangulating everything that gets cut, but probably didn't know about the ExtractCellsByRegion solution ;) Best regards, Bruno |
Hi Bruno,
thanks for your answer. "Extract by region" works fine. My collegue told me in the meantime that there is the "checkMesh" command. I think by using both of them it should be possible to be sure that the mesh is ok. Best regards, Sandu |
