How to choose end time for a steady state problem |
March 5, 2010, 02:46 |
KGN
I am using "rhopSonicFoam" solver for solving 3d steady inviscid flow around ONERA M6 wing. How to decide the end time? Ma=0.84, alpha=3.04 Properties of air R-287.05 J/kgK, gamma-1.4, T-255.6K Computational domain size is 11m x 5m x 10m (Hexahedral). No.of cells = 341797 time step = 5e-07 |
March 5, 2010, 05:54 |
Ulf Bunge
that is an interesting question. My suggestion is that you observe the development of the initial residuals for every equation for the cycles ('time' steps). If you have sufficient (computation) time and perform this (kind of) simulation or case setup for the first time, I would suggest you do the simulation as long as possible to get an idea of how the residuals develop over computation time (and how low they can go) and try to find a suitable optimum for quality of results (i.e. reduction of change in residual for every cycle - which is not always the same ) and computational effort (time). So, unfortunately, no general guideline available ... Best regards, Ulf. |
March 25, 2010, 21:49 |
Alberto Passalacqua
Rep Power: 36 |
You can additionally track the evolution of which you know the behaviour, and check when it stops evolving.
It is always a good idea to add a "physical" convergence criterion to the one based on residuals. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Single Bubble | Gerrit Senger | CFX | 4 | March 12, 2007 16:29 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
Has anyone successfully used transition modell..p2 | PetrK | CFX | 12 | May 26, 2006 16:27 |
