Proper Pressure Boundary Conditions for Buoyant Flow
Old   March 25, 2010, 13:16
Default Proper Pressure Boundary Conditions for Buoyant Flow
Matthew J. Churchfield
mchurchf is on a distinguished road
To whom can answer,
I am trying to understand why the following is occurring:
I am using a version of buoyantBoussinesqPisoFoam modified so that it can be used with LES models. I have a case in which I am trying to solve for atmospheric boundary layer flow and have a domain that is 1000m tall. I initialized the solution at cell centers and boundary faces such that p = 0 at the ground and p = -9810 m^2/s^2 at the top of the domain with a linear variation in between. (Note that the p variable is pressure/rho, I am using gravity = -9.81m/s^2, and since this is incompressible, all that really matters is pressure gradient--the pressure level is arbitrary, so it is okay to have negative pressure.) The initial solution also has some small random perturbations in velocity near the surface. Temperature is set to constant throughout the domain, so no buoyancy-induced turbulence generation should occur. I am not using a wall function for these initial trials to get the solver running correctly, just no-slip (note, this isn't really correct for atmospheric flow). All lateral boundary conditions are periodic.
If I set the pressure boundary conditions to fixedGradient, the solution become laminar after some time. If I set the pressure boundary conditions to fixedValue at 0 and -9810 at bottom and top respectively, the solution becomes very turbulent after the same amount of time. I can use pisoFoam (no gravity) with zeroGradient boundary conditions and get the same laminar result as using fixedGradient with buoyantBoussinesqPisoFoam.
Any idea why the use of fixedGradient versus fixedValue on p would affect the solution so greatly?
Thanks,
Matt
mchurchf is offline   Reply With Quote
Pressure boundary conditions hiras FLUENT 22 July 27, 2015 02:38
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 09:59
