Unable to load lib file: "undefined symbol"
Like Tree4Likes
  • 1 Post By wyldckat
  • 1 Post By dancfd
  • 2 Post By ancolli
Old   March 25, 2010, 10:50
Default Unable to load lib file: "undefined symbol"
gfilip is on a distinguished road
Hello everyone,
I am trying to add a new dynamicFvMesh type in 1.6.x. I have compiled the source with wmake libso, with no errors and the .so file is placed inside the $FOAM_USER_LIBBIN directory.
I have added the library into my controlDict, but upon execution of the solver (pimpleDyMFoam), I receive the following warning and error:
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 79
    could not load /home/greg/OpenFOAM/greg-1.6.x/lib/linuxGccDPOpt/libmyVivFvMesh.so: undefined symbol: _ZTVN4Foam22mySinkTrimMotionFvMeshE
Create mesh for time = 0
Selecting dynamicFvMesh mySinkTrimMotionFvMesh
--> FOAM FATAL ERROR:
Unknown dynamicFvMesh type mySinkTrimMotionFvMesh
I have attempted this with both 1.5.x and 1.6.x, and with both, I obtain the same warning and error. Any ideas?
Thanks,
-Greg
gfilip is offline   Reply With Quote
Old   March 25, 2010, 19:14
Retired Super Moderator
Bruno Santos
Greetings Greg,
I don't have experience in building additional libraries for OpenFOAM, but I have dealt with a lot of missing symbols when trying to cross-compile OpenFOAM in Linux to run in Windows.
If you said on which code you based your new dynamicFvMesh, it would be a bit more easier for me to estimate where exactly you haven't defined the class "Foam::mySinkTrimMotionFvMesh", which dlLibraryTable complains about. That should be something like:
namespace Foam
class mySinkTrimMotionFvMesh : public dynamicFvMesh
And so forth in the H file (not sure about the public dynamicFvMesh bit), and in the C part:
Foam::mySinkTrimMotionFvMesh( variables_necessary_here )
At the very least, the library should be properly loaded now, but will likely croak somewhere else Like I said, with an example library to base myself on, this is what I can estimate.
Best regards,
Bruno
PS: shouldn't you have posted this question on this (OpenFOAM Programming and Development) part of the OpenFOAM forum?
calf.Z likes this.
Old   March 31, 2010, 11:51
Hi Bruno,
Thank you for your help. I managed to resolve my issue, and you are right, I should have posted in the programming section of the forum. Sorry about that.
-Greg
Old   August 29, 2010, 12:05
Daniel
dancfd is on a distinguished road
Hi Greg,
How did you resolve your issue? I am receiving a similar error when I run blockMesh and paraFoam:
--> FOAM Warning :
    in file db/dlLibraryTable/dlLibraryTable.C at line 78
    could not load /home/dan/OpenFOAM/dan-1.7.0/lib/linux64GccDPOpt/libfvMotionNewSolvers.so: undefined symbol: _ZTIN4Foam17motionDiffusivityE
Thank you,
Dan
Mahmoud Abbaszadeh likes this.
dancfd is offline   Reply With Quote
Old   August 30, 2010, 05:40
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by dancfd View Post
Hi Greg,
--> FOAM Warning :
Thank you,
Dan
It's only a warning, so you should be fine (the solver will hopefully provide the missing symbol). If it bothers you go to system/controlDict and comment out the libs-entry for running these utilities
gschaider is offline   Reply With Quote
Old   August 31, 2010, 22:52
Daniel
Thank you, Bernhard!
Old   January 11, 2019, 11:40
Alejandro
ancolli is on a distinguished road
I know that is a really old post... I am having a similar problem. With paraview 4.4 is just giving a warning, not loading the library, that is ok, i can continue...
--> FOAM Warning :
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libregionCoupledSolidFluid.so:...
but with newer versions it is crashing, giving me the following error:
I/O    : uncollated
/opt/paraviewopenfoam56/lib/paraview: symbol lookup error: /home/nicolas/OpenFOAM/nicolas-dev/platforms/linux64GccDPInt32Opt/lib/libregionCoupledSolidFluid.so: undefined symbol: _ZN4Foam22temperatureCoupledBaseC2ERKNS_7fvPatchERKNS_10dictionaryE
Do you know how should I proceed to solve the error?
ancolli is offline   Reply With Quote
Old   January 11, 2019, 12:20
Alejandro
Solved. It was just a missing library that i found by doing:
grep "_ZN4Foam22temperatureCoupledBaseC2ERKNS_7fvPatchERKNS_10dictionaryE" $FOAM_LIBBIN/*.so
Thanks to this post: ParaFoam or Praview segmentation fault only when I have a lib linked in controlDict
wyldckat and crubio.abujas like this.
Old   May 26, 2022, 08:48
Mahmoud
Mahmoud Abbaszadeh is on a distinguished road
this did not work for me
Mahmoud Abbaszadeh is offline   Reply With Quote
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 16:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
