Interfaces like Gambit
Old   March 25, 2010, 14:51
Default Interfaces like Gambit
Jorge Muņoz
L3munoz is on a distinguished road
Hi everybody!
I'm a newbie in Openfoam and i wanted to ask u something related to interfaces. I used for a long time Gambit and there it's possible to create a interface in such a way that two adjacent volumes can have a different mesh model but thanks to the interface condition FLUENT was able to interpolate from one to the other.
My question is if it's possible to do it in Openfoam as well? I created my mesh in Gambit and knowing that it can be imported in Openfoam i wasnt sure how to perform that condition...
Any help is welcome, so please i'd appreciate any advice...
Regards,
Munoz.
L3munoz is offline   Reply With Quote
Old   March 25, 2010, 16:35
BastiL
bastil is on a distinguished road
Dependent on how your meshes look like you can try converting the interface-cells to polyhedrals (stichMesh, 1.6.x or 1.5-dev). However, this may fail/damage your mesh.
Instead of this you can use the ggi-Feature (generic grid interface, 1.5-dev only!). It is stable and validated but slow on very large cases due to improveable parallelisation.
Regards Bastian
bastil is offline   Reply With Quote
Old   March 25, 2010, 16:59
Jorge Muņoz
thanks bastil!
so does it mean that there is no way to input a interface condition to a surface like in FLUENT, no? damn it! therefore i should try to create a better mesh...
Old   March 25, 2010, 17:15
BastiL
Originally Posted by L3munoz View Post
thanks bastil!
No that is wrong.. The GGI in OpenFOAM is the same than an Interface in FLUENT.
Regards Bastian
Old   March 25, 2010, 17:18
Jorge Muņoz
woo sorry, u're right, i misunderstood ur post...however this of being slow...it's also slower in fluent than not using it, does it work in the same way in OpenFoam or it's even slower than FLUENT one?
Old   March 25, 2010, 17:21
BastiL
I did not realise FLUENT to be much slower with it. However, OpenFOAM can slow down (dependent on model size, number of interfaces and number of cores to run on) significantly.
Regards Bastian
Old   March 25, 2010, 17:29
Jorge Muņoz
Ok Bastian,
thanks a lot for ur replies and opinion!
regards,
Munoz.
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Does Gambit has a maximum allowable grid number? spartan1516 ANSYS Meshing & Geometry 7 March 25, 2010 09:08
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
Generating big meshes with GAMBIT on NT Andrew Ooi FLUENT 12 February 2, 2000 22:26
