conjugateHeatFoam:given field does not correspond to patch
Old   April 30, 2010, 12:56
Default conjugateHeatFoam:given field does not correspond to patch
Leonardo Nettis
dinonettis is on a distinguished road
Hi everybody,
I was trying to simulate a CHT problem, a 2d cylinder in cross-flow, by means of conjugateHeatFoam. I think everything it's ok in the settings and in particular:
------------------- SOLID SIDE--------------------
interface
type regionCouple;
nFaces 80;
startFace 1150;
shadowRegion region0;
shadowPatch sphere;
attached on;
-------------------FLUID SIDE-------------------
sphere
type regionCouple;
nFaces 80;
startFace 15920;
shadowRegion solid;
shadowPatch interface;
attached on;
this should be ok since the interface patch is correctly defined on both side in the boundary files.
However I get the following error message when I try to run it:
given field does not correspond to patch. Patch size: 80 field size: 0
From function PatchToPatchInterpolation::faceInterpolate(const Field<Type> ff)
in file /home/nettis/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/PatchToPatchInterpolate.C at line 133.
FOAM aborting
Any idea about that??
thanks in advance,
Dino
dinonettis is offline   Reply With Quote
Old   April 30, 2010, 13:40
Leonardo Nettis
ok,
I found the problem, the remoteField in the BCs was declared as DT in the T file!!
Have a nice weekend.
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
