Can OpenFOAM handle Third-Rank Tensor
Old   May 7, 2010, 04:12
Default Can OpenFOAM handle Third-Rank Tensor
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Hi Foamers,
In the documentation for OpenFOAM the rank-3 tensor is mention. But I can't find a corresponding class in the OpenFOAM code. And there seems rare information on this forum. Anyone have an idea where to find it? Or there is no class like that in the OF.
Thanks in advance.
Jinbiao
JinBiao is offline   Reply With Quote
Old   May 7, 2010, 21:00
Alberto Passalacqua
What do you have to do? Solve a transport equation for a 3x3 matrix as unknown? Manipulate tensors?
OpenFOAM can do that with fvTensorMatrix and volTensorField / surfaceTensorField.
If you provide some more detail, we can answer better ;-)
Best,
Alberto Passalacqua
Old   May 9, 2010, 01:06
Jinbiao Xiong
Alberto, thanks for your reply.
I am implementing a second moment closure for reynolds stress. Here I have to solve equations for a symmetric third rank tensor, u_i*u_j*u_k. The highest rank of tensor involved is rank 4.
For a better understanding, I provide the major equations below
rms = root mean square
D(u_i*u_j*u_k)/Dt = P_i,j,k + phi_i,j,k + d_i,j,k + eps_i,j,k
d_i,j,k = d( rms(u_i*u_j) * rms(u_k*u_l) + rms(u_k*u_j) * rms(u_i*u_l) + rms(u_i*u_k) * rms(u_j*u_l) ) / dt
Best
Jinbiao
Old   May 9, 2010, 01:20
Alberto Passalacqua
A transport equation for a symmetric tensor can be solved using fvSymmTensorMatrix, while for asymmetric tensors you have to use fvTensorMatrix.
If you have higher rank matrices, you have to deal with them independently (you can either use scalar equations for each component (easier and faster to do), or extend fvMatrix (more complicated)).
P.S. You can take a look at the implementation of Reynolds stress models too.
Best,
Alberto Passalacqua
Old   May 9, 2010, 02:28
Jinbiao Xiong
Alberto, thank you so much for the encouraging message.
Actually I am solving a matrix for symmetric rank 3 tensor. I am trapped at the beginning because I can not find a class for rank 3 tensor. Do you know where to find it or I have to write this into OpenFOAM by myself?
Thanks again.
Regards.
Jinbiao
Old   May 9, 2010, 02:36
Alberto Passalacqua
For symmetric tensors (not field):
http://foam.sourceforge.net/doc/Doxy...ymmTensor.html
For symmetric tensor fields:
http://foam.sourceforge.net/doc/Doxy...nsorField.html
Best,
Alberto Passalacqua
Old   May 9, 2010, 02:41
Jinbiao Xiong
Sorry, I am still confused about this.
These two classes are for rank 2 tensors. The components and operators of rank 3 tensor is different from provided by them. How can I relate them together?
Thanks again.
Jinbiao
Old   May 9, 2010, 09:03
Sandeep Menon
deepsterblue will become famous soon enough
27 components... Hmm.. That doesn't exist as yet, but I don't see why not. You'd have to write your own rank-3 tensor class, but although the extension process is straightforward, writing all that code is not. Taking its gradient, for instance, would be quite a laborious process indeed.
I guess you would still have to solve such a system in the conventional segregated sense (one component at a time). Hopefully, there's some way in which you can manipulate your equations to reduce the rank.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   May 9, 2010, 12:27
Alberto Passalacqua
Sorry for the confusion. I should stop answering late... ;-)
As Sandeep said, there is no implementation of rank > 2 tensors in OpenFOAM. Simply use scalar transport equations, maybe collected in a list to have a cleaner code.
Best,
Alberto Passalacqua
Old   May 9, 2010, 20:47
Alberto Passalacqua
Some additional hints that might help you to carry your 27 equations without writing too much spaghetti code
You can collect equations in a PtrList defined as
PtrList<fvScalarMatrix> myScalarEquations(nScalars);
where nScalars is the number of scalars you want to use (remember, it starts for 0 and ends at 26 if you have a complete rank 3 tensor).
To set your equations you can loop for i = 0 to i < nScalars, adding each scalar equation to the PtrList as follows:
for (int i = 0; i < nScalars; i++)
   myScalarEquations.set
      i,
      new fvScalarMatrix
        // Put the terms of your equation here, as usual
Once defined, you can relax all of them with
   myScalarEquations[i].relax();  // you can put a label inside relax to use always the same URF
and then you can solve them with
   myScalarEquations[i].solve();  // you can put a label inside solve to specify the linear solver only once in fvSolution (see pimpleFoam to see how this is done).
You can use PtrList in a similar way to collect fields. The idea is always the same.
I hope this helps (and it doesn't confuse you more than what I did before ).
Best,
Alberto Passalacqua
Old   May 9, 2010, 21:31
Jinbiao Xiong
Alberto and Sandeep, Thanks a lot.
Now I have the direction to solve my problem. I will post it here, if I have further questions.
Many thanks again. By the way, spaghetti tastes very good.
tensor rank 3 OFU OpenFOAM 0 November 18, 2009 04:10
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Tensor Rank Oliver Main CFD Forum 3 August 12, 1998 14:48
