MusigFoam for complete evaporation
Old   May 16, 2010, 13:20
Question MusigFoam for complete evaporation
Robert Langner
Robat is on a distinguished road
Hi foamers!
If I'm not on the wrong track:
- musigFoam is a multiphase Euler approach
- and Euler needs at least one continuous phase.
But needs Euler one (=always the same) continuous phase or just one (unspecific)?
For instance: If I might have a complete evaporation where the old liquid continuous phase breaks up but a new gas phase become persistent.
Do I receive reasonable results in that case or better use other approaches?
Thanks in advance,
Robert
Robat is offline   Reply With Quote
Old   May 16, 2010, 14:46
Holger Marschall
holger_marschall is on a distinguished road
Send a message via Skype™ to holger_marschall
You are right
The problem does not lie in the method itself as it is based upon the concept of interpenetrating continua - a quite general concept. As such (a priori) the role of the phases is absolutely interchangeable. However, due to averaging you end up with unclosed terms in your governing equations which represent the interphase exchange of mass, momentum and such... And to model these unclosed terms reasonable you might want to base your model on the presumption that say phase a is disperse while b is continuous.
Generally I would say the Eulerian-Eulerian approach is the right one being the most flexible. However, flexibility comes at one price to pay: You need to model - appropriately and at best on a physical sound basis.
Do you consider this evaporation process starting within the bulk phase (homogeneous/heterogeneous nucleation)?
best,
Holger Marschall
web: http://www.holger-marschall.info
mail: holgermarschall@yahoo.de
holger_marschall is offline   Reply With Quote
Old   May 17, 2010, 05:02
Robert Langner
Thanks for your quick reply.
Summed up: musigFoam is generally suitable for that but it's reasonable to define a continuous phase.
best,
My fluid heats from normal liquid to overheated gas. The evaporator is pretty complex shaped so I need to split the struktur an calculate it step by step. In result I can't presumpt the flow regime for every step and with it don't know which phase is locally continuous.
Besides that the micro scale seems to make me much more trouble. Yesterday I tried a shot in the dark but as I scaled down my mesh (to 4mm channel diameter): checkMesh shew me some inverted face pyramids as my cell sizes droped below 1µm.
Are there any limits for cell sizes around µm scale ?
Regards,
Robert
musicfoam
CFX Liquid Evaporation Model Jinx CFX 3 January 28, 2010 16:31
CFX - Evaporation problem AlessandroD CFX 0 August 18, 2009 06:03
evaporation on the surface of liquid nitrogen dodo FLUENT 0 March 3, 2008 04:37
DPM Modelling: Colloid droplet evaporation Meng Wai Woo FLUENT 1 August 1, 2007 00:27
Defining Evaporation - A How To Guide. Owen FLUENT 1 July 25, 2005 09:56
