May 25, 2010, 06:29 |
Paraview rendering quality
sutopo
Hi
Recently I installed OpenFOAM-1.6 on my laptop under OpenSUSE 11.1. Installation was successful even using Qt 4.5.3 including running paraFoam from lid-driven cavity flow tutorial. However, i have to turn off the KDE desktop effects or suspending Kwin composition for enabling clear view without flickering. The still problem is lack rendering view of ParaView to show the distribution on surface. It seems from lack of 3D rendering in my laptop. The below link is the result of pressure distribution from lid-driven cavity flow. Laptop uses Intel 915GM Express chipsets on Pentium M 1.6GHz with 2.0G total RAM and 3D acceleration is on. http://img189.imageshack.us/img189/5...w3b2452010.png Any clues to solve it? Is it necessary to recompile ParaView with Qt 4.3.5? ParaView with Qt 4.5.3 did well running except rendering, though. Any helps are appreciated. |
May 25, 2010, 08:32 |
Anton Kidess
Rep Power: 29 |
I'm not sure if I understood what you are expecting, but I think you want interpolated values instead of the sharp cell values (which are very blocky due to your coarse mesh). In the display tab select "point" p instead of "box" p, and you should see a nicer image.
May 25, 2010, 13:16 |
#3 | |
sutopo
Best regards |
intel, paraview, qt 4.5.3, rendering |
[OpenFOAM] Distributed ParaView and PV3FoamReader | micalil | ParaView | 4 | July 1, 2010 05:09 |
[ICEM] Hex refinement negative quality afterwards | Anorky | ANSYS Meshing & Geometry | 8 | March 22, 2010 03:25 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
Rendering Fluent Data in Paraview | burk | FLUENT | 4 | July 7, 2008 03:32 |
Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 12:59 |
