Questions about tutorial from User Guide :confused: |
May 25, 2010, 10:50 |
Ovidiu Michiu
Rep Power: 16 |
Hello, I'm very new in OpenFOAM and i already have a lot of problems in running the first tutorial. I manage to install OF 1.6 on a Suse distribution, 32 bits(my conection is to a server,VNC). After i copy all the tutorials on a separated file, i try to run "cavity". I did all the steps from the user guide and after I run the "blockMesh" comand, i want it to see the mesh with paraview and i could saw it. WHY? also, it wasn't created any cavity.openFOAM file. i went to the next step to run the analysis, by typing "icoFoam". it mayed the analysis, but still it any cavity.openFOAM (cavity.foam) file wasn't created it. WHY? I try to run other simple cases, like "cylinder", from potentialFOAM directory, but i had the same problem like at the first one. also, when i typing "icoFoam" comand i receive this error: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties cannot open file file: /root/OpenFOAM/run/tutorials/basic/potentialFoam/cylinder/constant/transportProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 62. FOAM exiting //***********// The same error apear for other cases that i want it to run. Can somebody give me some advices or answers??? Thk you, Best regards, Ovidiu |
May 25, 2010, 11:46 |
Alberto Passalacqua
Rep Power: 36 |
It seems it just doesn't find the transportProperties file.
How do you try to run paraview and from where (you have to be inside the case directory or specify the path with the command line options)? The "cavity.foam" file is created by paraFoam and removed when you close it. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; May 25, 2010 at 11:49. Reason: added comment |
May 25, 2010, 12:42 |
Ovidiu Michiu
Rep Power: 16 |
ok. it worked, but another problem appeard.
If I'm typing paraFoam, the "cavity.openFOAM" file is created in paraview, but on the screen appear a box with Microsoft visual studio and the following error "an unhandled win32 exception occured in Xming.exe[5084] Possible Debuggers: New instance of Visual Studio 2005 New instance of Visual Studio 2008 Do you want to debug using the selected debugger?" If im selection "yes" the program is not responding if im selected "no" close the paraview. my connection is to a linux server at the distance. best regards, Ovidiu |
May 25, 2010, 12:53 |
Alberto Passalacqua
Rep Power: 36 |
No idea. I use OpenFOAM on Linux. Sorry.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
May 25, 2010, 15:10 |
#5 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all,
If you still want to use ssh with X11 forwarding, perhaps you can try:
Best regards, Bruno
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
CFX User Guide query | siw | CFX | 0 | August 21, 2008 03:15 |
particle user routines | Felix | CFX | 1 | July 24, 2006 12:32 |
confused about particle user source sub-routine | wayne | CFX | 1 | August 30, 2005 06:55 |
Fluent 6.1 user guide | dingdong | FLUENT | 6 | May 17, 2004 11:17 |
