solution diverges when linear upwind interpolation scheme is used
Old   May 29, 2010, 01:23
Default solution diverges when linear upwind interpolation scheme is used
subash
subash is on a distinguished road
I am trying to simulate supersonic flow over a ramp. The solution works well when I use a limitedlinear 1 interpolation scheme for div, but when it is converted to a second order interpolation scheme(linear upwind) the courant number which floats around 0.45 for quite sometime seems to jump suddenly to values above thousand with the number of inner iterations reaching 1000's. I have tried to run it with constant courant number also but still the solution diverges.
the fvScheme file which works fine is as shown below
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phid,p) Gauss limitedLinear 1;
div(phiU,p) Gauss limitedLinear 1;
div(phi,h) Gauss limitedLinear 1;
div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian((rho*(1|A(U))),p) Gauss linear corrected;
laplacian(alphaEff,h) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default yes;
p;
And the modified file which is diverging is as follows
ddtSchemes
default Euler;
gradSchemes
divSchemes
default none;
div(phi,U) Gauss linearUpwind Gauss;
div(phi,k) Gauss linearUpwind Gauss;
div(phi,epsilon) Gauss linearUpwind Gauss;
div(phi,R) Gauss linearUpwind Gauss;
div(phi,e) Gauss limitedLinear 1;
laplacianSchemes
default none;
laplacian(alphaEff,e) Gauss linear corrected;
default linear;
snGradSchemes
default corrected;
fluxRequired
default yes;
p;
can someone please tell me how do I recognise(in OpenFoam) whether a transient problem being run is explicit or implicit.
Also how do I get the problem to converge with second order upwind scheme.
Thank you.
subash is offline   Reply With Quote
vanLeer Interpolation Scheme with interFoam rassilon OpenFOAM Running, Solving & CFD 0 April 8, 2010 02:51
what interpolation scheme should I use? titio OpenFOAM Running, Solving & CFD 0 October 12, 2009 11:03
Water pump OpenFOAM 15 ANSYS CFX 110 comparation waynezw0618 OpenFOAM Running, Solving & CFD 39 March 5, 2009 12:57
Upwind scheme KM CFX 4 September 27, 2007 14:41
Upwind flux scheme Biga FLUENT 0 January 12, 2006 12:41
