dynamicRefineFvMesh in 2 directions
Like Tree4Likes
  • 1 Post By AGRONOM
  • 3 Post By AGRONOM
Old   May 31, 2010, 03:23
Default dynamicRefineFvMesh in 2 directions
Victor Fleischer
Victor is on a distinguished road
Hallo at all,
I am trying to apply the dynamicRefineFvMesh to detonation simulations in order to increase the mesh refinement at the detonation front.
The problem is that the dynamicRefineFvMesh uses the hexRef8 code for refinement, so that the mesh is refined in all 3 dimensions. In order to decrease the number of cells it would be sufficient to refine the mesh in 2 directions.
I already tried to do through the hexRef8 code, but i do not understand what is going on there!?!
Is there anybody how has experience with this or knows how to solve this problem??
Thanks in advance for any help or hint!
Victor
Victor is offline   Reply With Quote
Old   June 3, 2010, 14:35
Default Same problem here...
Pablo Caron
pcaron is on a distinguished road
Hello Victor,
I'm working in 2D simulations, so I have both empty or wedge faces. If I use the refine option the simulation aborts. This is because, after refinement, the mesh has more than 1 element in the normal direction to the empty face.
I also tried to read hexref8, but it's to complex for me.
Maybe if an advanced user read this can help us? Please help!
I think the idea is to detect the empty direction, but I don't have the knowledge.
Regards
Pablo
pcaron is offline   Reply With Quote
Old   June 7, 2010, 08:29
AGRONOM is on a distinguished road
Hi all!
The multiDirRefinement is more suitable for 2d simulations, because it allows to specify refinement directions.
I used to to make a cellSet, by choosing cells with high pressure gradient, and apply the refineMesh.
The problem is that I can't unrefine mesh (when pressure gradient decreases) due to lack of the refinement history.
mm.abdollahzadeh likes this.
AGRONOM is offline   Reply With Quote
Old   June 7, 2010, 09:45
Pablo Caron
Thanks agronom! I'll give it a try.
How do you create the cellSet? Do you include it into the solver?
Can you share a simple case? Maybe the cavity problem using this refine option.
Regards
Pablo
Old   June 7, 2010, 11:02
But I do not guarantee that you'l find something useful in the attachment.
Running this case you should stop the solver to refine the mesh and then continue simulation.
In this case myRefineMesh is used with -dict and -time options i.e.
myRefineMesh -dict -time 3
mySonicFoam is a the same as sonicFoam, but for the pressure gradient is
saved in the time dir.
myRefineMesh consists of the cellSet and the refineMesh utilities, so myRefineMesh creates the cellSet, based on the pressure grad from the time dir.
Old   June 7, 2010, 12:16
Pablo Caron
Hi Agronom! This is enough information!!! It's my time to work now!
Thank you!!
Pablo
Old   June 28, 2010, 05:46
Victor Fleischer
Does anybody know, if there is a possibility to unrefine cells after using multiDirRefinement???It would be great help for me!
[ICEM] Periodic boundaries in two directions jphastings ANSYS 3 January 14, 2022 06:06
Periodic boundary condition in 2 directions arash FLUENT 21 July 25, 2018 12:44
dynamicRefineFvMesh/ solidBodyMotionFvMesh FG_HSRM OpenFOAM 3 July 19, 2012 12:39
How to set directions for porous media ? Judpom FLUENT 0 May 11, 2009 10:22
Periodic Boundary Conditions in two directions david FLUENT 0 April 1, 2002 07:24
