February 9, 2010, 09:51 |
Problem using single precision in simpleFoam
Bastian Nebenfuehr
Rep Power: 16 |
Hello everybody,
I'm running simpleFoam simulations in double precision and in order to speed them up, I would like to switch to single precision. This works fine in the beginning of the simulation and the simulation is about 40% quicker (in terms of simulation time per iteration), but suddenly the simulation diverges. I get an error message that states that there is a "floating point exception". I don't have bounding epsilon or k before the simulation blows up. Does anyone of you know, what could be the reason? It would help me so much. Best regards, Bastian. |
February 11, 2010, 10:22 |
This was my solution
Luca Gasparini
Rep Power: 17 |
Dear Bastian,
it is definitely worth running single precision but with turbulence model it is likely that occasional underflow/overflow happens in single precision. This causes exception and ends a computation which was otherwise going fine. To avoid it edit the file bashrc in folder etc and comment the line export FOAM_SIGFPE= so that exception will not be raised anymore. Regards, Luca |
February 11, 2010, 10:26 |
Bastian Nebenfuehr
Rep Power: 16 |
Dear Luca,
that sounds great, but will the change influence the result of the computations in some way or is this just a thing to trick the computer? Thx already and best regards, Bastian |
February 11, 2010, 10:31 |
Luca Gasparini
Rep Power: 17 |
Dear Bastian,
In my experience it will have absolutely no effect (apart from the slight difference you might anyway find switching from double to float), but you might want to look at the particular turbulence model you are using and figure out which part of it (likely damping function or similars) is causing it, to be sure it will not compromise the results. Regards, Luca |
February 11, 2010, 10:38 |
Bastian Nebenfuehr
Rep Power: 16 |
Dear Luca,
ahh okay, then I will just run some cases in single precision and check out how the results change or if they are still acceptable. Best, Bastian |
February 17, 2010, 07:31 |
Bastian Nebenfuehr
Rep Power: 16 |
Hi Luca,
I tried the solution, you supposed, but I still have the same problem. The simulation stops, because of a floating point exception. In the following I attach the error-message, which I get in the log-file. Hopefully somebody else had a similar problem already. Regards, Bastian Here comes the error message: Code:
Time = 191 DILUPBiCG: Solving for Ux, Initial residual = 0.0183009, Final residual = 0.00139391, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.0260962, Final residual = 0.00202694, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0598852, Final residual = 0.00420837, No Iterations 2 GAMG: Solving for p, Initial residual = 0.833212, Final residual = 0.0341513, No Iterations 2 time step continuity errors : sum local = 0.0358474, global = 4.17163e-05, cumulative = 0.0421732 DILUPBiCG: Solving for epsilon: solution singularity bounding epsilon, min: 2.45278e-09 max: 1.18469e+18 average: 3.41778e+11 DILUPBiCG: Solving for k, Initial residual = 0.419389, Final residual = 3.7141e-15, No Iterations 25 bounding k, min: -1810.15 max: 2.95828e+10 average: 311408 ExecutionTime = 1847.54 s ClockTime = 1874 s Time = 192 DILUPBiCG: Solving for Ux, Initial residual = 0.0130778, Final residual = 0.000781722, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.0188701, Final residual = 0.000931275, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0457371, Final residual = 0.00249969, No Iterations 2 GAMG: Solving for p, Initial residual = 0.780956, Final residual = 0.0524846, No Iterations 2 time step continuity errors : sum local = 0.0444382, global = 0.000165461, cumulative = 0.0423386 [3] #0 [1] #0 [2] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigFpeHandler(int) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigFpeHandler(int) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigFpeHandler(int) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigFpeHandler(int) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [0] #2 in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [3] #2 in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [1] #2 in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [2] #2 ???????? in "/lib64/libc.so.6" [0] #3 Foam::PBiCG::solve(Foam::Field<float>&, Foam::Field<float> const&, unsigned char) const in "/lib64/libc.so.6" [3] #3 Foam::PBiCG::solve(Foam::Field<float>&, Foam::Field<float> const&, unsigned char) const in "/lib64/libc.so.6" [1] #3 Foam::PBiCG::solve(Foam::Field<float>&, Foam::Field<float> const&, unsigned char) const in "/lib64/libc.so.6" [2] #3 Foam::PBiCG::solve(Foam::Field<float>&, Foam::Field<float> const&, unsigned char) const in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [0] #4 Foam::fvMatrix<float>::solve(Foam::Istream&) in "/vcc/a in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [1] #4 Foam::fvMatrix<float>::solve(Foam::Istream&)ns/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [3] #4 Foam::fvMatrix<float>::solve(Foam::Istream&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so" [2] #4 Foam::fvMatrix<float>::solve(Foam::Istream&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libfiniteVolume.so" [0] #5 Foam::lduMatrix::solverPerformance Foam::solve<float>(Foam::tmp<Foam::fvMatrix<float> > const&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libfiniteVolume.so" [3] #5 Foam::lduMatrix::solverPerformance Foam::solve<float>(Foam::tmp<Foam::fvMatrix<float> > const&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libfiniteVolume.so" [1] #5 Foam::lduMatrix::solverPerformance Foam::solve<float>(Foam::tmp<Foam::fvMatrix<float> > const&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libfiniteVolume.so" [2] #5 Foam::lduMatrix::solverPerformance Foam::solve<float>(Foam::tmp<Foam::fvMatrix<float> > const&) in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [0] #6 Foam::incompressible::RASModels::realizableKE::correct() in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [3] #6 Foam::incompressible::RASModels::realizableKE::correct() in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [1] #6 Foam::incompressible::RASModels::realizableKE::correct() in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [2] #6 Foam::incompressible::RASModels::realizableKE::correct() in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [0] #7 in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [3] #7 in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [1] #7 in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so" [2] #7 mainmainmainmain in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam" [0] #8 __libc_start_main in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam" [3] #8 __libc_start_main in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam" [1] #8 __libc_start_main in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam" [2] #8 __libc_start_main in "/lib64/libc.so.6" [3] #9 Foam::regIOobject::readIfModified() in "/lib64/libc.so.6" [0] #9 Foam::regIOobject::readIfModified() in "/lib64/libc.so.6" [1] #9 Foam::regIOobject::readIfModified() in "/lib64/libc.so.6" [2] #9 Foam::regIOobject::readIfModified() in "/vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam" [gbwcs7-21:17607] *** Process received signal *** [gbwcs7-21:17607] Signal: Floating point exception (8) [gbwcs7-21:17607] Signal code: (-6) [gbwcs7-21:17607] Failing at address: 0x1a1aae000044c7 [gbwcs7-21:17607] [ 0] /lib64/libc.so.6 [0x2ba6ff829c30] [gbwcs7-21:17607] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2ba6ff829bb5] [gbwcs7-21:17607] [ 2] /lib64/libc.so.6 [0x2ba6ff829c30] [gbwcs7-21:17607] [ 3] /vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_5FieldIfEERKS2_h+0xdf9) [0x2ba6fec1b5f9] [gbwcs7-21:17607] [ 4] /vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libfiniteVolume.so(_ZN4Foam8fvMatrixIfE5solveERNS_7IstreamE+0x164) [0x2ba6fdecdd44] [gbwcs7-21:17607] [ 5] /vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so(_ZN4Foam5solveIfEENS_9lduMatrix17solverPerformanceERKNS_3tmpINS_8fvMatrixIT_EEEE+0x50) [0x2ba6fd42ac80] [gbwcs7-21:17607] [ 6] /vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/lib/linux64GccSPOpt/libincompressibleRASModels.so(_ZN4Foam14incompressible9RASModels12realizableKE7correctEv+0x1c29) [0x2ba6fd455849] [gbwcs7-21:17607] [ 7] /vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam [0x415716] [gbwcs7-21:17607] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2ba6ff817184] [gbwcs7-21:17607] [ 9] /vcc/ans/cfd/of/1.5-090529-vcc.1/OpenFOAM-1.5.x/applications/bin/linux64GccSPOpt/simpleFoam(_ZN4Foam11regIOobject14readIfModifiedEv+0x1a9) [0x413be9] [gbwcs7-21:17607] *** End of error message *** |
February 18, 2010, 01:49 |
Luca Gasparini
Rep Power: 17 |
Dear Bastian,
I think you have a different problem here: iteration 191 shows that solution for k and epsilon is alerady diverging so that the successive failing is not a big surprise to me. My experience was for sudden floating point error in a well converging solution. It might be that the switch to single precision is influencing your solution if you are using fine near-wall mesh for k-eps. I do not have much experience on this, but I guess you should check your solution starting from a few iterations before it stops. Regards, Luca |
February 19, 2010, 03:40 |
Bastian Nebenfuehr
Rep Power: 16 |
Dear Luca,
I agree that timestep #191 is already looking strange and that it is not a big surprise that I get divergence. However, timestep #189 looks still perfectly fine. The solution diverges more or less in 2-3 timesteps. Below you can see the last few timesteps. Best regards, Bastian Code:
Time = 187 DILUPBiCG: Solving for Ux, Initial residual = 0.00332962, Final residual = 0.0001476, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00133389, Final residual = 9.25218e-06, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.00284297, Final residual = 8.63122e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.062382, Final residual = 0.00186959, No Iterations 2 time step continuity errors : sum local = 0.000670455, global = -8.67323e-06, cumulative = 0.0421226 DILUPBiCG: Solving for epsilon, Initial residual = 0.00140286, Final residual = 4.18191e-09, No Iterations 7 DILUPBiCG: Solving for k, Initial residual = 0.0017069, Final residual = 3.07222e-15, No Iterations 18 ExecutionTime = 1725.62 s ClockTime = 1753 s Time = 188 DILUPBiCG: Solving for Ux, Initial residual = 0.00330507, Final residual = 0.000115972, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00130667, Final residual = 7.23427e-06, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.00280713, Final residual = 7.8791e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.062679, Final residual = 0.00186556, No Iterations 2 time step continuity errors : sum local = 0.000663852, global = -2.72414e-06, cumulative = 0.0421199 DILUPBiCG: Solving for epsilon, Initial residual = 0.00139674, Final residual = 4.17446e-09, No Iterations 7 DILUPBiCG: Solving for k, Initial residual = 0.00169037, Final residual = 9.02943e-15, No Iterations 17 ExecutionTime = 1732.3 s ClockTime = 1759 s Time = 189 DILUPBiCG: Solving for Ux, Initial residual = 0.00327983, Final residual = 0.000119982, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00127992, Final residual = 1.599e-05, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.00277252, Final residual = 8.75667e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0622074, Final residual = 0.00188927, No Iterations 2 time step continuity errors : sum local = 0.00066771, global = 3.24493e-06, cumulative = 0.0421232 DILUPBiCG: Solving for epsilon, Initial residual = 0.00139073, Final residual = 4.16778e-09, No Iterations 7 DILUPBiCG: Solving for k, Initial residual = 0.00167427, Final residual = 1.96518e-15, No Iterations 18 ExecutionTime = 1739.06 s ClockTime = 1766 s Time = 190 DILUPBiCG: Solving for Ux, Initial residual = 0.00325495, Final residual = 0.000104864, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00125293, Final residual = 8.50088e-06, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.00273899, Final residual = 8.8469e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0614532, Final residual = 0.00188187, No Iterations 2 time step continuity errors : sum local = 0.000662112, global = 8.30823e-06, cumulative = 0.0421315 DILUPBiCG: Solving for epsilon, Initial residual = 0.00138482, Final residual = 4.16147e-09, No Iterations 7 DILUPBiCG: Solving for k, Initial residual = 0.00165835, Final residual = 13.8498, No Iterations 1001 bounding k, min: -6.48451e+10 max: 6.10749e+10 average: 84.3805 ExecutionTime = 1840.75 s ClockTime = 1868 s Time = 191 DILUPBiCG: Solving for Ux, Initial residual = 0.0183009, Final residual = 0.00139391, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.0260962, Final residual = 0.00202694, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0598852, Final residual = 0.00420837, No Iterations 2 GAMG: Solving for p, Initial residual = 0.833212, Final residual = 0.0341513, No Iterations 2 time step continuity errors : sum local = 0.0358474, global = 4.17163e-05, cumulative = 0.0421732 DILUPBiCG: Solving for epsilon: solution singularity bounding epsilon, min: 2.45278e-09 max: 1.18469e+18 average: 3.41778e+11 DILUPBiCG: Solving for k, Initial residual = 0.419389, Final residual = 3.7141e-15, No Iterations 25 bounding k, min: -1810.15 max: 2.95828e+10 average: 311408 ExecutionTime = 1847.54 s ClockTime = 1874 s |
February 19, 2010, 03:54 |
#9 |
Luca Gasparini
Rep Power: 17 |
Dear Bastian,
I think the problem is iteration 190: you see that k equation failed to solve, doing 1001 iterations (the default limit) with diverging residual. This is something that sometimes happens when you run in parallel, even in double precision, using DILUPBiCG (I'm quite sure that it would be ok if you could run on a single cpu). I suggest you require a small relative tolerance and either limit the max iter to a small value (5 or 10) which will prevent diverging or you better switch to a smoothSolver for turbulence fields. Regards, Luca |
February 19, 2010, 04:05 |
#10 |
Bastian Nebenfuehr
Rep Power: 16 |
Dear Luca,
thx for the answer, I will try your suggestions immediately. Running on a single CPU, however, is impossible, since the mesh is rather big (13M cells). I will keep you updated about the progress. Best regards, Bastian |
April 30, 2010, 02:20 |
#11 |
maddalena
Rep Power: 23 |
Yup! This worked perfectly fine for me. I had similar problem of Bastian, running on two processors and using DILUPBiCG, but now they are solved. Thanks Luca!
May 28, 2010, 08:09 |
#12 | |
Vishal Jambhekar
Rep Power: 17 |
I guess here there is no issue of compromising with the result. rather the floating point error occurs as at that specific node sudden jump of fall in the value occurs (or might be division by zero i.e by very small quantity). This is causing operator overflow for floating point and thus the error occurs......fooling the comp using edited "bashc" will only ask the solver to go ahead.......!!! In the error posted by basned before i could see that the is a singler solution for solving k...that is the main reason for floating point exception......!!!
Cheers, Vishal Jambhekar... "Simulate the way ahead......!!!" |
May 28, 2010, 08:16 |
#13 |
Bastian Nebenfuehr
Rep Power: 16 |
Hello Vishal,
you are right, the entry in the bash forces the solver to continue, which eventually does not solve the problem. However, the solution to the problem was for me, as suggested by Luca, to use the smoothSolver instead of the PBiCG solver for turbulence fields. Have a nice weekend! |
May 28, 2010, 08:30 |
#14 |
Vishal Jambhekar
Rep Power: 17 |
i am really sorry i am little weak on this part....can you tell me where can i get reference to these different solvers...as i would love to know the selection criteria for them...or if u have can u maill me.... at
vishalljambhekar@gmail.com
May 28, 2010, 09:22 |
#15 | |
Vishal Jambhekar
Rep Power: 17 |
rsingh@knicklenker:~/openfoam/SurgeTank/SymTANKMESHMOD> #0 Foam::error:rintStack(Foam::Ostream&) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #4 void Foam::MULES::explicitSolve<Foam::geometricOneField , Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #6 main in "/mnt/opt.net/src/OpenFOAM/OpenFOAM-1.6/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/interFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 ^C [1]+ Floating point exceptioninterFoam > log
June 7, 2010, 00:54 |
#16 |
Srikara Mahishi
Rep Power: 17 |
Hi Everybody,
I am using simpleFoam to solve an incompressible flow. Following some of the suggestions here I commented the line "export FOAM_SIGFPE=" in the bashrc file. After some 290 iterations, the solution was showing solution singularity for the velocity fields. But the simulation was running without giving me any error. I used to get the sigfpe error before I edited the above line in bashrc. I used smoothsolvers for the turbulence fields and they were running fine. For the velocity and pressure fields I had the PBiCG option. Could anybody tell me if there is anything else I could do to improve the solution? Thank you and Regards, Srikara Last edited by srikara; June 7, 2010 at 00:55. Reason: incomplete post |
Display Modes | |
Single or double precision | Jonas Larsson | Main CFD Forum | 16 | June 20, 2017 06:53 |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Problem running simpleFoam on a multi element airfoil | vinz | OpenFOAM Running, Solving & CFD | 18 | April 11, 2013 11:26 |
Problem on multiple processors..works fine on single processor! | skabilan | OpenFOAM Running, Solving & CFD | 2 | December 5, 2009 12:19 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
