June 10, 2010, 13:03 |
Basic question to buoyantBoussinesqPisoFoam
Christoph
Rep Power: 16 |
Hi!
I have a (simple) question, using buoyantBoussinesqPisoFoam. Before getting into calculations with convection, I am trying to resolve the principal behaviour of the OF solver. I have set up a room, 5m in height, constant temperature, with a gravitational body force of 10 m/s^2. Am I correct assuming that the "pressure" p in OF is pressure divided by density, i.e. p=pressure/density? Having a graviational body force acceleration of 10 m/s^2, I was expecting a pressure difference of 50 Pa from 0 to 5m. paraFoam however shows me a pressure difference of about 100 [Pa]? [m^2/s^2]? from the floor to the ceiling. - What is the variable p in OF? pressure [Pa] or pressure/density [m^2/s^2]? - Having no fluid flow, only gravitational body forces, why does the pressure not decrease with rho*g*height, i.e. 50Pa at 5m height and g=10 m/s^2? http://www.bilder-space.de/show_img....&size=original Last edited by kriz; June 10, 2010 at 13:18. Reason: added picture |
June 11, 2010, 19:50 |
Ovie Doro
Rep Power: 16 |
Hi Kriz,
I think you are right about the pressure in bouyantBousinessqFoam. The pressure is normalized by density as you described. With respect to pressure variation, If I recall correctly, I am not sure the hydrostatic pressure variation for a gas (air in your case) ought to be significant under the conditions you describe in your simulation. |
June 12, 2010, 03:35 |
Jiang
Rep Power: 16 |
How about your boundary condition for pressure ?
If fixed value, then should not be a uniform value. |
Display Modes | |
[GAMBIT] Basic Question - Mesh Quality | SheffieldStudent | ANSYS Meshing & Geometry | 8 | December 15, 2010 17:24 |
Basic question | forsumit | OpenFOAM | 0 | April 7, 2010 10:46 |
basic question for pressure BC | vivien | OpenFOAM | 0 | November 23, 2009 05:01 |
Basic Poiseuille flow simulation question | Ashish | Main CFD Forum | 0 | October 2, 2007 13:05 |
Basic LES question | toyCFD | Main CFD Forum | 3 | August 23, 2006 15:09 |
