March 16, 2023, 07:12 |
chkMultiRegionFoam
Rep Power: 5 |
I try the first time chkMultiRegionFoam with a simple example. Two circular fluid bodies separated by a pipe (as you find it in an double jacket heat exchanger), flow in different directions and one fluid transfer heat ,through the separting piece of pipe, to the other. Now I try to figure out the T boundary in the 0-folder. There is one patch fluidint_to_pipe and I do not know which would be the suitable condition for that. I didn't find any tutorial aswell which I could take as a template. Can somebody give me a hint how to proceed ? Thx a lot. Marcus |
March 16, 2023, 08:58 |
Yann
Rep Power: 26 |
Region interfaces usually use one of the following boundary conditions for T:
Depending on the version you are using, you can run some of the chtMultiRegionFoam tutorials to have examples :
Regards, Yann |
