chtmultiregionFoam - Gradient at Coupling boundary
Old   February 17, 2011, 08:39
Default chtmultiregionFoam - Gradient at Coupling boundary
alireza j
FekrKon is on a distinguished road
Dear Friends,
I was wondering if it is possible to have a gradient boundary condition in the interface boundary at the same time with coupling boundary condition.
I aim to have a coupling boundary between solid and fluid and at the same time it should be a heat source in the interface boundary. I checked almost all related thread and also
http://www.cfd-online.com/Forums/ope...egionfoam.html
which is mostly to add heat source in the solver rather than on the boundary.
I was also thinking to have one side (fluid part) coupling:solidWallMixedTemperatureCoupling and the other side (solid part) fixedGradient: solidWallHeatFluxTemperature , but it didn't work.
I appreciate if you help me in this issue.
FekrKon is offline   Reply With Quote
Old   April 2, 2012, 11:50
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
today i tried to test a case with chtMultiregionFoam.
my case includes natural convection in an enclosure with a block at the bottom. the bottom surface of block was heated.
the strange thing is that the temperature is not passing throgh solid zone to fluid zone. I am using turbulentTemperatureCoupledBaffleMixed as the boundary condition on the interface of soid and liquid zone.
I thinck there should be sth related to boundary condition. I will be too much thankful to recive you oponions .
mm.abdollahzadeh is offline   Reply With Quote
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
temperature normal gradient on a boundary Sandrine Main CFD Forum 2 June 10, 2009 16:34
normal temperature gradient on a boundary Sandrine FLUENT 0 June 10, 2009 12:29
Boundary condition vector field gradient from two sides of patch face quba OpenFOAM 0 December 12, 2007 05:26
