turbulentTemperatureCoupledBaffle in chtMultiRegion
Old   August 19, 2010, 14:22
Default turbulentTemperatureCoupledBaffle in chtMultiRegion
stawrogin is on a distinguished road
Dear Foamers,
I make my first steps with chtMultiRegion and I'm a little bit confused about the coupling of fluid and solid domains.
In the tutorials a
is used between the fluid and the solid domian with a
K K;
on both sides, the fluid and solid side. On the solid side it is quite clear but I wonder if this setting on the fluid side can only be used in laminar flow or low-Reynolds cases (the example is a laminar case). If the flow is turbulent I think
K none;
has to be used to force the solver to balance the heat flux using the RAS-model. Or is the corrected heat flux calculated by the alphat wall function? Is there anybody who has experience with this patch and can tell me how K has to be set?
Thanks in advance
Best regards
Stawrogin
stawrogin is offline   Reply With Quote
Mass transfer and chtmultiregion Bufacchi OpenFOAM Programming & Development 0 August 2, 2010 20:28
