AutoCAD file import enGrid / Netgen
Old   August 4, 2010, 08:03
Default AutoCAD file import enGrid / Netgen
Nico T
deniggo is on a distinguished road
I’m trying to import an AutoCAD 2009 geometry into Netgen or enGrid for volume meshing.
The exported .stl file of AutoCAD consists already of very coarse surface-polygons, which I can not delete or refine in enGrid. Netgen doesn’t even show the .stl file (white window).
How can I import AutoCAD files in meshing-software as a whole simple block?
Is it possible to import (closed) polyline into meshing software and use extrusion for further volume modelling?
Thanks!
deniggo is offline   Reply With Quote
Old   August 4, 2010, 09:38
Oliver Gloth
ogloth is on a distinguished road
usually a water-tight STL file should import well into enGrid. Having said that: Sometimes it doesn't and it can be beneficial to first import into a different software (e.g. ParaView or Blender) and then export in a format that enGrid digests better. If you could post an example of what you are trying to import I can offer to have a look at it (preferably directly on the enGrid forum: http://engits.eu/forum).
Btw, Which version of enGrid are you using?
Regards,
Oliver
ogloth is offline   Reply With Quote
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
How to import a AutoCAD file into Design Modeler? CFD-Jay FLUENT 1 July 8, 2010 10:49
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
import autocad file ritmat FLUENT 5 June 1, 2007 12:19
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
