August 19, 2010, 08:37 |
NSRDS functions, liquid properties
Rep Power: 15 |
Hallo Foamers,
the liquid properties of C10H22 are defined in the file .../src/thermophysicalModels/liquids/C10H22/C10H22.H The density is calculated with the NSRDS function 5 in .../src/thermophysicalModels/thermophyicalFUnctions/NSRDSfuntions/NSRDSfunc5/NSRDSfunc5.H Here it seems, that the density is only dependent on temperature, and not on pressure. Is the pressure dependency of density taken into account in OpenFoam? All answers welcome. Markus |
August 19, 2010, 12:05 |
MSR CHANDRA MURTHY
Rep Power: 17 |
I worked on kerosene(C12H26). i had the similar doubt when i started the work.
In the present 1.7.x code, the density depends only on temperature. i don't think it is too difficult to make it function of both T & P. |
August 20, 2010, 05:10 |
#3 | |
Rep Power: 15 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Addiotional scalar properties: gas or liquid? | Julie Polyakh | Siemens | 0 | June 20, 2004 15:54 |
Properties of liquid Hydrogen. | Santosh Kumar Mukka | Main CFD Forum | 0 | July 29, 2003 20:43 |
