Why should we define both P and U for boundaries? |
October 17, 2010, 23:50 |
Dear Foamers,
What should be velocity boundary condition (U) type for outlet of a problem which we want set pressure (P) as fixedValue. We can't suppose it zeroGradient because it is not fully developed at outlet. and i don't know why should we define both of P and U for boundaries in OpenFOAM. |
October 18, 2010, 04:20 |
Christian Lucas
you have to define BC for each field you are solving, so you need a BC for U and p. Other CFD software like fluent or cfx does the same (without telling you). zeroGradients is the correct BC (or better inletOutlet) for U at the outlet. Of course your BC has an effect on the solution (as in all CFD software), so you must place the outlet BC far (at least a bit) away from the area of interest. Regards, Christian |
October 18, 2010, 04:55 |
#3 | |
the problem is in processing algorithm depend on its form, in boundary cell we set pressure and the algorithm try to calculate a velocity which satisfy continuity and ... so setting both of U and P leads to have more equations than unknowns and this is the cause that other softwares like Fluent don't need to define both of them. |
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 22:13 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 10:23 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
