Momentum eq fulfilled???
Old   October 19, 2010, 09:40
Default Momentum eq fulfilled???
Niklas Winkler
nikwin is on a distinguished road
I need to compute the spatial terms of the momentum eq. in rhoPisoFoam. As a check I added a part to rhoPisoFoam which computes all the terms of the momentum eq. to see that it is fulfilled. However accoding to my calculations it's not, even though the residual printed during runTime is below tolerance. Any suggestion of what could be wrong?
Thanks
/NW
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "initContinuityErrs.H"
#include "readTimeControls.H"
#include "compressibleCourantNo.H"
#include "setInitialDeltaT.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.run())
#include "readPISOControls.H"
#include "setDeltaT.H"
runTime++;
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "rhoEqn.H"
#include "UEqn.H"
// --- PISO loop
for (int corr=1; corr<=nCorr; corr++)
#include "hEqn.H"
#include "pEqn.H"
turbulence->correct();
rho = thermo.rho();
Info << "START CHECK AFTER rho=thermo.rho()" << endl;
volVectorField UEqn4(IOobject("UEqn4",runTime.timeName(),mesh,IOo bject::NO_READ,IOobject::AUTO_WRITE),mesh,dimensio nedVector("UEqn4",dimless,vector::zero));
fvVectorMatrix UEqn4Matrix
fvm::ddt(rho, U)
+ fvm::div(phi, U)
+ turbulence->divDevRhoReff(U)
+ fvc::grad(p)
vectorField UEqn4Residual(UEqn4Matrix.residual());
forAll (mesh.cells(),cellI)
UEqn4[cellI] = -UEqn4Residual[cellI]/mesh.V()[cellI];
vector mean(sum(UEqn4.internalField()*mesh.V())/sum(mesh.V()).value());
Info << "max: " << max(UEqn4.internalField()) << endl;
Info << "min: " << min(UEqn4.internalField()) << endl;
Info << " mean: " << mean << endl;
Info << "variance.x: " << sum(sqr(mean.x()-UEqn4.internalField().component(0)))/mesh.nCells() << endl;
Info << "variance.y: " << sum(sqr(mean.y()-UEqn4.internalField().component(1)))/mesh.nCells() << endl;
Info << "variance.z: " << sum(sqr(mean.z()-UEqn4.internalField().component(2)))/mesh.nCells() << endl;
Info << "END CHECK AFTER rho=thermo.rho()" << endl;
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
Results from mesh with 2e6 cells, pipe flow.
max: (6181064.994 6807506.826 6688472.669)
min: (-6694996.468 -7079812.026 -6947027.568)
mean: (-77.21956025 27.10909829 -53.67802351)
variance.x: 3019294370
variance.y: 2737483314
variance.z: 2314573170
nikwin is offline   Reply With Quote
Momentum and displacement thickness: du/dy calculation Josh CFX 13 October 27, 2013 14:38
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 02:33
Nonstaggered Grids and Momentum Interpolations S. Wang Main CFD Forum 3 March 2, 2001 13:44
