fvMatrix - internalCoeffs_ and boundaryCoeffs_ ? |
October 19, 2010, 16:08 |
Alicja M
Hi *,
I have read the following wiki article to lduMatrix and lduAddressing: http://openfoamwiki.net/index.php/Matrices_in_OpenFOAM This article is a good starting point for understanding the lduMatrix and the corresponding lduAddressing. Unfortunately this article does not cover the fvMatrix which has lduMatrix as a base class. I also searched at this forum but did not find an answer. And here are my questions concerning the fvMatrix: - What is the meaning and the usage of the members internalCoeffs_ and boundaryCoeffs_? - What does "pseudo-matrix coeff" mean and for what is it used? fvMatrix.H, lines 129-135: Code:
//- Boundary scalar field containing pseudo-matrix coeffs // for internal cells FieldField<Field, Type> internalCoeffs_; //- Boundary scalar field containing pseudo-matrix coeffs // for boundary cells FieldField<Field, Type> boundaryCoeffs_; Alicja |
October 20, 2010, 08:29 |
Santiago Marquez Damian
Rep Power: 23 |
Hi, ala, internalCoeffs_ and boundaryCoeffs_ are the contribution of BC to matrix coefficients, they are calculated in diff operators and applied at solving time, for example, for divergence (gaussConvectionScheme.C):
00067 template<class Type> 00068 tmp<fvMatrix<Type> > 00069 gaussConvectionScheme<Type>::fvmDiv 00070 ( 00071 const surfaceScalarField& faceFlux, 00072 GeometricField<Type, fvPatchField, volMesh>& vf 00073 ) const 00074 { 00075 tmp<surfaceScalarField> tweights = tinterpScheme_().weights(vf); 00076 const surfaceScalarField& weights = tweights(); 00077 00078 tmp<fvMatrix<Type> > tfvm 00079 ( 00080 new fvMatrix<Type> 00081 ( 00082 vf, 00083 faceFlux.dimensions()*vf.dimensions() 00084 ) 00085 ); 00086 fvMatrix<Type>& fvm = tfvm(); 00087 00088 fvm.lower() = -weights.internalField()*faceFlux.internalField(); 00089 fvm.upper() = fvm.lower() + faceFlux.internalField(); 00090 fvm.negSumDiag(); 00091 00092 forAll(fvm.psi().boundaryField(), patchI) 00093 { 00094 const fvPatchField<Type>& psf = fvm.psi().boundaryField()[patchI]; 00095 const fvsPatchScalarField& patchFlux = faceFlux.boundaryField()[patchI]; 00096 const fvsPatchScalarField& pw = weights.boundaryField()[patchI]; 00097 00098 fvm.internalCoeffs()[patchI] = patchFlux*psf.valueInternalCoeffs(pw); 00099 fvm.boundaryCoeffs()[patchI] = -patchFlux*psf.valueBoundaryCoeffs(pw); 00100 } 00101 00102 if (tinterpScheme_().corrected()) 00103 { 00104 fvm += fvc::surfaceIntegrate(faceFlux*tinterpScheme_().correction(vf)); 00105 } 00106 00107 return tfvm; 00108 }
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
October 20, 2010, 16:51 |
Alicja M
Hi Santiago,
thanks for your reply. Ok, so that are matrix contributions from BC. I took a look at fvMatrix.C, at the functions - addToInternalField() - addBoundaryDiag() - addBoundarySource(): Code:
00061 template<class Type> 00062 template<class Type2> 00063 void Foam::fvMatrix<Type>::addToInternalField 00064 ( 00065 const unallocLabelList& addr, 00066 const tmp<Field<Type2> >& tpf, 00067 Field<Type2>& intf 00068 ) const 00069 { 00070 addToInternalField(addr, tpf(), intf); 00071 tpf.clear(); 00072 } 00073 00114 00115 template<class Type> 00116 void Foam::fvMatrix<Type>::addBoundaryDiag 00117 ( 00118 scalarField& diag, 00119 const direction solveCmpt 00120 ) const 00121 { 00122 forAll(internalCoeffs_, patchI) 00123 { 00124 addToInternalField 00125 ( 00126 lduAddr().patchAddr(patchI), 00127 internalCoeffs_[patchI].component(solveCmpt), 00128 diag 00129 ); 00130 } 00131 } 00132 00148 00149 template<class Type> 00150 void Foam::fvMatrix<Type>::addBoundarySource 00151 ( 00152 Field<Type>& source, 00153 const bool couples 00154 ) const 00155 { 00156 forAll(psi_.boundaryField(), patchI) 00157 { 00158 const fvPatchField<Type>& ptf = psi_.boundaryField()[patchI]; 00159 const Field<Type>& pbc = boundaryCoeffs_[patchI]; 00160 00161 if (!ptf.coupled()) 00162 { 00163 addToInternalField(lduAddr().patchAddr(patchI), pbc, source); 00164 } 00165 else if (couples) 00166 { 00167 tmp<Field<Type> > tpnf = ptf.patchNeighbourField(); 00168 const Field<Type>& pnf = tpnf(); 00169 00170 const unallocLabelList& addr = lduAddr().patchAddr(patchI); 00171 00172 forAll(addr, facei) 00173 { 00174 source[addr[facei]] += cmptMultiply(pbc[facei], pnf[facei]); 00175 } 00176 } 00177 } 00178 } 00179 Now i don't know, why are this coefficients separately stored (as boundaryCoeffs and as internalCoeffs) and not immediately added to the 'real' matrix, and i have to (?) add this coefficients firstly during the solve( ) process. Regards, Ala |
August 27, 2018, 22:00 |
#4 | |
Reviewer #2
Rep Power: 10 |
Is it possible to apply different boundary condition for the different operator? Any suggestions? Thanks, Rdf |
February 22, 2019, 19:24 |
Rep Power: 23 |
Hmm, the BC's are intended to be selected just by patch...
boundarycoeffs_, fvmatrix. internalcoeffs_, pseudo-matrix coeffs |
