Temperature-dependent properties and mass conservation in porousExplicitSourceReactin
Old   October 26, 2010, 06:46
Default Temperature-dependent properties and mass conservation in porousExplicitSourceReactin
Robertas N.
r08n is on a distinguished road
Hi *,
I modified the 'porousExplicitSourceReactingParcelFoam' to include heat sources in the energy equation and set up a very simple simulation: a box filled with pure N2, no mass flows (U=uniform(0,0,0)) and a uniform field of the heat source, in order to raise the temperature; that's just for testing purposes -- the setup will get more complex in the future. The solver uses
the polynomial coefficients defined in constant/thermo.incompressiblePoly for temperature-dependent parameters: density, heat capacity @p=const and some other. As the temperature rises, the density gets lower, therefore, the total mass in the box (calculated as m=sum_over_cells(rho(cell)*V(cell))) diminishes, but the pressure stays constant. Of course, this setup is incorrect -- it must use heat capacity @ constant volume, not @ constant pressure, and assume the compressible fluid (gas in this case). I have a few questions:
1) Is it possible to obtain somewhere the polynomial coefficients for heat capacity at constant volume? Where are the data in thermo.incompressiblePoly taken from? I couldn't find any references -- ChemKin, maybe?
2) Why does the pressure stay constant in the current simulation? Isn't 'porousExplicitSourceReactingParcelFoam' meant to be compressible solver?
The modified energy equation looks like this:
solve
fvm::ddt(rho, h) + mvConvection->fvmDiv(phi, h)
- fvm::laplacian(turbulence->alphaEff(), h)
pWork() + parcels.Sh() + radiation->Sh(thermo) + Q_heat
All the terms on the RHS are zero, except for Q_heat, which is defined as a volScalarField with constant power density (in W/m^3).
Did I overlook something? Thank you for any pointers, hints, keywords for searching...
r08n is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Mass Properties of Axial Fan Bladegen Katamish CFX 2 May 12, 2009 05:39
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
