interFoam and K-omega
Old   November 17, 2010, 10:10
Default interFoam and K-omega
Olivier Benichou
olivier78 is on a distinguished road
Hello Foamer,
I'm trying to run interFoam with the k-omega SST turbulence model but I have been unsuccessful so far. I believe it is possible as the k-e model runs fine. Has anyone got an example ?
Also which equation should I use for the Omega coeficient. The value used in the bike tutorial example seem a lot higher that the one found by applying the standard equation:
omega= 0.09^(-0.25)*(sqrt(k))/L
cheers,
Olivier
olivier78 is offline   Reply With Quote
interfoam, k-omega
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
interFoam vs icoFoam on a single-phase case nuovodna OpenFOAM Running, Solving & CFD 1 May 1, 2014 09:37
Slow interFoam compared with other CFD tools? Ralph M OpenFOAM Programming & Development 1 November 17, 2010 06:46
Moving from simpleFoam to interFoam with alpha = 0 kjetil OpenFOAM Running, Solving & CFD 1 November 8, 2009 20:04
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
