November 27, 2010, 08:22 |
paraview stoped working
Benjamin Nwobodo
Rep Power: 15 |
Hi there,
After copying and recompiling the IcoFoam to my_icoFoam as directed in the OpenFOAM wiki "how to add Temperature to icoFoam" tutorial, the new solver runned successfully. But unfortunately, running the paraFoam gives the following error: benjy@benjy-laptop:~/OpenFOAM/benjy-1.7.1/run/my_icoFoam_cavity$ paraFoam created temporary 'my_icoFoam_cavity.OpenFOAM' /opt/openfoam171/bin/paraFoam: 142: paraview: not found benjy@benjy-laptop:~/OpenFOAM/benjy-1.7.1/run/my_icoFoam_cavity$ ^C benjy@benjy-laptop:~/OpenFOAM/benjy-1.7.1/run/my_icoFoam_cavity$ The paraview does not also work when i try to run other cases from the tutorials. I am new user of OpenFOAM and don't know what next to do. Could anyone be of help to me in solving this problem? |
November 27, 2010, 08:36 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Benjamin,
You are not alone on this a solution already exists: http://www.cfd-online.com/Forums/ope...not-found.html Best regards and good luck! Bruno
November 27, 2010, 09:36 |
Benjamin Nwobodo
Rep Power: 15 |
Hi Bruno,
million thanks for the help, it works now. But i get the following warning: OpenGL Warning: Failed to connect to host. Make sure 3D acceleration is enabled for this VM. Benjamin |
November 28, 2010, 10:23 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Benjamin,
But if you are using Ubuntu in a real machine (i.e., not in a virtual machine), then you haven't installed the graphic card drivers. Best regards, Bruno
November 28, 2010, 20:57 |
Benjamin Nwobodo
Rep Power: 15 |
Hi Bruno,
You are right. i am using ubuntu in a vitualbox VM and have turned the 3D acceleration ON and it works now perfectly. Thanks for the efforts. Benjamin. |
Display Modes | |
[General] Paraview nice animation | PyGloo | ParaView | 4 | June 7, 2012 13:34 |
working with paraview | gandesk | OpenFOAM | 0 | November 19, 2010 12:48 |
ParaView Stopped Working | AlanR | OpenFOAM | 5 | April 17, 2010 05:55 |
[OpenFOAM] ParaView 3.6.1 3D viewer not working | will_avoid_comm_solvers | ParaView | 2 | March 9, 2010 17:13 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
