How to calculate double integration in OpenFOAM
Old   December 9, 2010, 01:18
Default How to calculate double integration in OpenFOAM
Vishal Nandigana
nandiganavishal is on a distinguished road
Dear Foamers,
I would like to know if we could integrate a variable over x and y at the same time respectively. I know integrate variable function can perform integration along x or y direction at a time. But is it possible to perform double integration in OpenFOAM.
Kindly let me know.
Thanks
Vishal Nandigana
nandiganavishal is offline   Reply With Quote
Old   December 9, 2010, 08:15
Bill Rosemurgy
brosemu is on a distinguished road
Hi Vishal,
Could you provide some more information about what you are trying to integrate and what it is you are trying to integrate over? I think I can help...
What is the name of the 1-D integration function that you mentioned?
- Bill
brosemu is offline   Reply With Quote
Old   December 9, 2010, 11:52
Vishal Nandigana
Dear Bill,
Thanks for the response. Basically I have a rectangular channel and I want to integrate a variable say 'u' along a desired length (say from x1 to x2) and across the entire cross section of the channel (i.e from y1 to y2). I would like you to throw some light with regard to this. I hope I made my point more clear now.
The function I was talking about to integrate in 1-D is integratevariable function in paraview.
Thanks
Vishal Nandigana
Old   December 9, 2010, 13:38
Bill Rosemurgy
Ok, so the method I was thinking of involves simply (or not so simply...) editing the actual solver that you are using to perform the integration for you. A for loop and some if-statements would do the trick, but only if you're comfortable doing that. Otherwise, it may be possible in Paraview, but I don't know how you'd do it.
- Bill
Old   December 9, 2010, 13:57
Vishal Nandigana
Dear Bill,
Thanks for the reply. The problem is the area I would like to integrate is not constant for all cases. The y direction is constant but not in x direction. I have to view the result and only then perform the x integration. So I wonder if changing the solver would help. Do correct me if I am wrong.
Thanks
Vishal Nandigana
Old   September 1, 2011, 06:41
isabel
isabel is on a distinguished road
Dear everybody,
I need to integrate a variable over x and y in a boundary condition. Can somebody write an example of how to do it?
Thanks in advance
isabel is offline   Reply With Quote
Old   September 1, 2011, 10:27
isabel
Dear everybody,
I was able to integrate a variable. I want to integrate a variable to obtain the average temperature and the average temperature gradient in a boundary condition, so I wrote this code:
label patchID = mesh.boundaryMesh().findPatchID("ABAJO");
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
const surfaceScalarField& magSf = mesh.magSf();
scalar Area = 0.0;
scalar sumArea = 0.0; //area of the boundary condition
scalar sumT = 0.0; //average temperature
scalar sumgradT = 0.0; //average temperature gradient
forAll(cPatch, facei)
Area = magSf.boundaryField()[patchID][facei];
sumArea += magSf.boundaryField()[patchID][facei];
sumT += T.boundaryField()[patchID][facei]*Area;
sumgradT += T.boundaryField()[patchID].snGrad();
Info << "Area " << sumArea << endl; //area of the boundary condition
Info << "Average T " << sumT/sumArea << endl; //average temperature
Info << "Average T " << sumgradT/sumArea << endl; //average temperature gradient
My code computes the average temperature Ok, but the line of the temperature gradient "sumgradT+=T.boundaryField()[patchID].snGrad(); " gives the following error:
integracion.H:41: error: no match for ‘operator+=’ in ‘sumgradT += Foam::fvPatchField<Type>::snGrad [with Type = double]()’
How can I obtain the magnitude of the temperature gradient?
Old   September 1, 2011, 11:01
Bernhard
Bernhard is on a distinguished road
Maybe this piece of code may be helpfull?
http://foam.sourceforge.net/docs/cpp/a03267_source.html
Bernhard is offline   Reply With Quote
Old   September 1, 2011, 14:10
isabel
It is very interesting, thanks. Finally, I was able to compute the average temperature and the average temperature gradient in the boundary condition. The problem is that the gradient computed is exactly half of the real gradient. Does anybody know why? The code is here:
scalar Area = 0.0;
volScalarField gradT = mag(fvc::grad(T));
gradT.boundaryField()[patchID]=T.boundaryField()[patchID].snGrad();
sumgradT += gradT[facei]*Area;
Info << "Average gradT " << sumgradT/sumArea << endl; //average temperature gradient
[OpenFOAM] How to calculate a custom field rres ParaView 4 November 16, 2012 04:24
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Testing of OpenFOAM 1.3alpha Commenced OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 February 7, 2006 07:31
