Steady Solver in OpenFoam
Old   January 3, 2011, 07:38
Default Steady Solver in OpenFoam
wwwjuventuscom is on a distinguished road
Hi Everyone,
I am a new guy to OpenFoam, now I am stuck with one problem that I need your help. I use Ansys CFX and OpenFoam to solve the "backward facing step" problem, which is a laminar, steady problem. However, in OpenFoam. all the steady solvers seem to get wrong results, for example, by using potentialFoam, the velocity at the singularity point is the biggest, which is obviously not the case, so is in simpleFoam. However, by using the transient solver such as icoFoam, the results is OK, but if the meshsize is very small, the timestep must be very small which means that it costs such huge amount of time to get the steady results.
So my questions is that is there a steady solver that just takes a few iterations and then solve the problem? If so, could you please tell me which solver?If not, what should I do then?
wwwjuventuscom is offline   Reply With Quote
Old   January 4, 2011, 14:54
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
May be this: http://www.amcaonline.org.ar/ojs/ind...File/3263/3186 could be useful.
Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   January 4, 2011, 19:01
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Try simpleFoam (steady-state solver), and turn off the turbulence. It will take longer than "a few" iterations, but a lot less than the transient solver.
julien.decharentenay is offline   Reply With Quote
If OpenFOAM can run different solver in different domain in the same time ? panda60 OpenFOAM Running, Solving & CFD 4 May 15, 2014 10:07
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Steady state solver for chemical reaction hamburgFoam OpenFOAM Running, Solving & CFD 2 January 8, 2010 08:34
New capability 6DOF solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 8 March 6, 2008 09:20
Steady and unsteady solver sam thompson FLUENT 1 April 20, 2006 12:39
