April 28, 2010, 09:33 |
compressible flow solver in OF1.6
KGN
Rep Power: 16 |
Hi all,
Why PISO & SIMPLE algorithms are used in OF for compressible flow problems. These algorithms are for pressure linked equation i.e. incompressible flows and for low Mach no flows. Even density based solver "rhoSonicFoam" uses PISO algorithm why? In compressible flows computation, we solve momentum equation to get velocity, energy equation to get temperature, density from continuity equation and pressure from perfect gas equation. correct me if i am wrong. If this is the case, then why PISO & SIMPLE come into picture. Thanks mecbe |
April 29, 2010, 11:04 |
April 29, 2010, 12:52 |
KGN
Rep Power: 16 |
I read the thread and it was mentioned that steady state problem has to be solved by Pseudo Transient for stability. Can you give some details on it, because i am in the process of converting the "rhoSonicFoam" inviscid density based transient compressible flow solver(this doesn't uses PISO algorithm). thanks mecbe |
April 30, 2010, 01:07 |
Alberto Passalacqua
Rep Power: 36 |
Please, define the problem you want to solve, or we cannot give any specific answer. What is the Mach number, for example?
In addition, what do you mean with "converting" rhoSonicFoam? It is already a transient solver, and it doesn't use the PISO algorithm because it is density based. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
April 30, 2010, 01:17 |
KGN
Rep Power: 16 |
Hi Alberto,
I want to solve transonic & supersonic inviscid steady flow over missile. Mach No -0.9,1.2,1.8 & 2.5. I saw the "rhoSonicFoam" code, it doesnt uses PISO algorithm, but in tutorial case file, it was there. sorry for that. I want to convert it to steady state solver, bcz transient solver takes lot of time to converge. One more question, can you explain about the slip boundary condition (other than given in the user guide). Also, i want to implement some more inviscid flux discretization schemes like AUSM, HLLC.. Can you give some advice on how to carry on. Thanks mecbe |
April 30, 2010, 01:40 |
#6 | ||
Alberto Passalacqua
Rep Power: 36 |
Best,
April 30, 2010, 02:37 |
KGN
Rep Power: 16 |
I will look into those two schemes.
What about implementing new inviscid flux computation schemes like AUSM, HLLC. thanks mecbe |
April 30, 2010, 12:06 |
#8 | |
Alberto Passalacqua
Rep Power: 36 |
http://www.cfd-online.com/Forums/ope...-aerofoam.html Best,
April 30, 2010, 12:50 |
#9 |
KGN
Rep Power: 16 |
Hi Alberto,
Thanks for the thread. I downloaded the solver. This will help a lot for my work. thanks mecbe |
December 25, 2010, 09:17 |
#10 |
senthilkumar.R
Rep Power: 15 |
Hi mecbe,
Please reply with AeroFOAM (its written for OF V 1.4.1) compatibility problem in OF V 1.6 + . |
Display Modes | |
High speed compressible flow through pipe | Munni | Main CFD Forum | 6 | December 7, 2015 11:33 |
compressible flow calculation error using rhoSimpleFoam solver | student4326 | OpenFOAM Running, Solving & CFD | 7 | November 2, 2015 11:34 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
About compressible flow at low mach | hit | Main CFD Forum | 2 | October 26, 2009 21:21 |
Incompressible and compressible flow | boris | FLUENT | 0 | February 20, 2002 03:08 |
