March 23, 2010, 11:29 |
Setup for verticalValves
Rep Power: 16 |
Does anyone of you has experience with the class engineTopoChangerMesh?
I try to run a test case with a moving piston and one vertical valve. I am using OF-1.5-dev. I am struggling with the engnineGeometrie file with the liftProfile. Hope someone of u can explain me or show how to set up the case! regards /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object engineGeometry; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //engineMesh layered; conRodLength conRodLength [0 1 0 0 0 0 0] 0.147; bore bore [0 1 0 0 0 0 0] 0.092; stroke stroke [0 1 0 0 0 0 0] 0.08423; clearance clearance [0 1 0 0 0 0 0] 0.00115; rpm rpm [0 0 -1 0 0 0 0] 1500; deformAngle 10; valvePosTol 1e-04; delta 0.0005; offSet 0.002; checkMesh on; engineTopoChangerMesh verticalValves; piston { patch piston; // patch none; coordinateSystem { type cartesian; origin (0 0 -0.09); axis (0 0 1); direction (0 1 0); } minLayer 0.002; maxLayer 0.0025; } valveSplitPoint (0 0 0); verticalValves ( valve { // Valve coordinate system coordinateSystem { type cylindrical; origin (0.02 0 0.12); axis (0 0 1); direction (0 1 0); } // Patch and zone names bottomPatch valveBottomIn; poppetPatch valveTopIn; stemPatch valveStem; curtainInPortPatch ValveCurtainPortIn; curtainInCylinderPatch ValveCurtainCylIn; detachInCylinderPatch valveDetachCyl1; detachInPortPatch valveDetachPort1; detachFaces 5 (364 366 368 370 371); // Vertex on edge of the step. For the converter stemEdge (0.023 0.003 0.12); // Valve diameter diameter 0.028; // Minimum valve lift minLift 0.00025; // Layer thickness minTopLayer 0.0007; maxTopLayer 0.0025; minBottomLayer 0.005; maxBottomLayer 0.01; liftProfile ( -540 0.01 ); } ); My output from openFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5-dev | | \\ / A nd | Revision: exported | | \\/ M anipulation | Web: http://www.OpenFOAM.org | \*---------------------------------------------------------------------------*/ Exec : dieselEngineFoamLayer Date : Mar 23 2010 Time : 16:40:32 Host : PID : Case : /home/peter/OpenFOAM/peter-1.5-dev/run/dieselEngineFoamValve nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create engine time Create mesh Selecting engineTopoChangerMesh verticalValves keyword liftProfileFile is undefined in dictionary "/home/peter/OpenFOAM/peter-1.5-dev/run/dieselEngineFoamValve/constant/engineGeometry::verticalValves::valve" file: /home/peter/OpenFOAM/peter-1.5-dev/run/dieselEngineFoamValve/constant/engineGeometry::verticalValves::valve from line 69 to line 107. From function dictionary::lookupEntry(const word& keyword) const in file db/dictionary/dictionary.C at line 213. FOAM exiting |
March 24, 2010, 03:55 |
Rep Power: 16 |
Does anyone of you know how to define the liftProfileFile or liftProfile entry in the engineGeometry dict?
I appreciate any help! regards |
March 24, 2010, 06:50 |
Rep Power: 16 |
Problem solved!
Just create in the engineGeometry file a link to a file with the lift profile. liftProfileFile "liftprofile.dat" Create the file liftprofile.dat in the constant folder with the entry: (0 0.0001) (1 0.0002) .... .... .... regards |
January 14, 2011, 09:04 |
Rep Power: 15 |
Hey Pete,
I found my problem with my test case, I think the liftProfileFile is not being read right. Could you maybe post a sample of yours? I need the correct syntax, should there be an empty line at the end, or that doesn't matter? I get liftProfileStart_=0, and also liftProfileEnd=0, so doing while (adjustedTheta < liftProfileStart_) { adjustedTheta += liftProfileEnd_ - liftProfileStart_; } in Foam::engineValve::adjustCrankAngle, it cycles!! Any hints? Best regards, abm |
January 14, 2011, 15:54 |
Rep Power: 16 |
A lift profile can look like this
(left column: CAD right column: lift in m regards Peter |
January 18, 2011, 05:24 |
Rep Power: 15 |
great, found my error, I thought it was a set of parenthesis per point, thanks mate
January 18, 2011, 14:09 |
Rep Power: 16 |
Great. Happy that I could help you.
Display Modes | |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 01:27 |
How I can setup Fluent for a Define_Profile on FZ? | Nuno | FLUENT | 5 | February 23, 2012 04:39 |
2D setup and 2D profile data file in CFX10 | Se-Hee | CFX | 3 | October 30, 2006 10:49 |
global panel and macro / environment setup | guang ai | Siemens | 10 | August 15, 2006 02:13 |
setup vof test problem | Fang Jin | FLUENT | 1 | June 14, 2005 09:27 |
