January 5, 2011, 16:40 |
Library syntax from Doxygen, how?
Charles
Rep Power: 18 |
As somebody with far too little knowledge of C++, I feel like a bit of an idiot to be asking this question, but will ask anyway. How do you determine what the syntax of a library is supposed to be from the Doxygen documentation?
Let me give an example: in the dynamicMeshDict, I want to change to a different type of diffusivity for the velocityComponentLaplacian solver. If the dic just contains "diffusivity" without arguments, the error listing will tell you what types of diffusivity are valid, but crucially, it doesn't tell you what further arguments you need to specify. So where do you find the template of what the syntax is supposed to look like? |
dictionary, doxygen, syntax |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 15:49 |
Help! I cann't make library | Bowling | FLUENT | 5 | May 12, 2004 04:56 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
Good library to solve huge linear system | Ricardo Bonon | Main CFD Forum | 3 | May 19, 2000 06:24 |
