October 17, 2011, 05:29 |
icofoam
douda gh
Rep Power: 14 |
when i execute icofoam i have the errors:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1 Exec : icoFoam Date : Oct 17 2011 Time : 10:24:24 Host : bahloul-desktop PID : 27918 Case : /home/bahloul/OpenFOAM/bahloul-2.0.1/run/tutorials/incompressible/icoFoam/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0.0164035 max: 0.1 DILUPBiCG: Solving for Ux, Initial residual = 0.993652, Final residual = 2.65556e-06, No Iterations 8 DILUPBiCG: Solving for Uy, Initial residual = 0.874416, Final residual = 1.917e-06, No Iterations 8 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/bahloul/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/home/bahloul/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 cfree in "/lib/tls/i686/cmov/libc.so.6" #4 operator delete(void*) in "/usr/lib/libstdc++.so.6" #5 operator delete[](void*) in "/usr/lib/libstdc++.so.6" #6 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>:perator=(Foam::tmp<Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/bahloul/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/bin/icoFoam" #7 main in "/home/bahloul/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/bin/icoFoam" #8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #9 Foam::UOPstream::write(char) in "/home/bahloul/OpenFOAM/OpenFOAM-2.0.1/platforms/linuxGccDPOpt/bin/icoFoam" Erreur de segmentation bahloul@bahloul-desktop:~/OpenFOAM/bahloul-2.0.1/run/tutorials/incompressible/icoFoam/cavity$ how to proceed to correct first: sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations |
October 17, 2011, 09:43 |
compiling pv3reader
douda gh
Rep Power: 14 |
when i execute the commande
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers wmSET ./Allwclean it works coorectly but for ./Allwmake i get the code: + [ -d /home/bahloul/OpenFOAM/ThirdParty-2.0.1/platforms/linuxGcc/paraview-3.10.1 -a -r /home/bahloul/OpenFOAM/ThirdParty-2.0.1/platforms/linuxGcc/paraview-3.10.1 ] and it stops i didn't inderstand whta's the probleme ans thnks for the help |
Density in icoFoam Densidad en icoFoam | manuel | OpenFOAM Running, Solving & CFD | 8 | September 22, 2010 04:10 |
problem when running icoFoam on a complex shape flow field | wendywu | OpenFOAM | 1 | May 20, 2009 23:40 |
IcoFoam Not Installed and blockMesh command not found | cesarbz | OpenFOAM Installation | 6 | July 4, 2008 04:44 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
