boundray conditions in OpenFoam
Old   February 8, 2011, 16:46
Default boundray conditions in OpenFoam
yu
xiyuqiu is on a distinguished road
Hello all,
I have a mesh generated from netgen and is now converted into foam format using netgenNeutralToFoam command. I ran a checkMesh and got the following.
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.0-21131bcbd876
Exec : checkMesh
Date : Feb 08 2011
Time : 13:43:22
Host : tribe.cse.ucdavis.edu
PID : 25031
Case : /home/yuhou/my_foam_test_dir/test_runs/lam_pipe
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 213440
internal faces: 197952
cells: 102848
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 102848
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
patch0 0 0 ok (empty)
patch1 14720 7408 ok (non-closed singly connected)
patch2 384 217 ok (non-closed singly connected)
patch3 384 217 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-15.2205 -12.5436 0) (7.77949 10.4564 224)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (6.97395e-16 4.61931e-17 2.7422e-19) OK.
Max cell openness = 3.15752e-16 OK.
Max aspect ratio = 8.26039 OK.
Minumum face area = 0.574487. Maximum face area = 5.89857. Face area magnitudes OK.
Min volume = 0.256933. Max volume = 2.45927. Total volume = 92844. Cell volumes OK.
Mesh non-orthogonality Max: 71.363 average: 31.0839
*Number of severely non-orthogonal faces: 14.
Non-orthogonality check OK.
<<Writing 14 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.759258 OK.
Mesh OK.
End
I tried to ran simpleFoam solver for this (this is just a pipe flow) but the code crashed. give
--> FOAM FATAL IO ERROR:
keyword patch0 is undefined in dictionary "/home/yuhou/my_foam_test_dir/test_runs/lam_pipe/0/p::boundaryField"
file: /home/yuhou/my_foam_test_dir/test_runs/lam_pipe/0/p::boundaryField from line 25 to line 46.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 456.
FOAM exiting
I think it is because I don't have the boundary condition defined.
How can I defined the boundary conditions here? Or it has to be defined in netgen? thank you so much.
xiyuqiu is offline   Reply With Quote
Old   February 9, 2011, 14:19
Jason G.
JasonG is on a distinguished road
It appears "patch0" is defined in netgen, but doesn't contain anything.
JasonG is offline   Reply With Quote
Old   February 9, 2011, 14:40
yu
Thanks, Jason. I will going into the patch. Do you know other than define them by index of vertex, is there a better way? and what are the options. I found inlet, outlet, fixwall and such. What happen if I would like to define say a parabolic velocity profile at the inlet or something. Is there are good tutorial on this topic? thank you so much
Old   February 9, 2011, 14:41
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
yu,
define the names of our patches in constant/polyMesh/boundary file.
use the same name of the patches to assign your BC's in 0/ directory.
that should work for you.
guilherme
aerothermal is offline   Reply With Quote
Old   February 9, 2011, 14:44
yu
Thank you Guilherme. I will try it right away.
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
Setting a boundary conditions mer OpenFOAM Running, Solving & CFD 1 November 24, 2005 13:53
