January 7, 2011, 18:24 |
Rotating channel
Hagen Müller
Hello Everyone,
I want to start a calculation on a rotating channel. In that case the governing equations change due to the Coriolis force. Has anybody adjusted a solver or turbulence model to capture these effects? Thanks for your help, hagen |
April 6, 2012, 00:17 |
#2 | |
Mo Ah.
Have you managed to solve this probem? I'm stuck on the same, I've tried using moving reference framce as well as simple UDF to incorporate coriolis and centrifugal forces, however I'm still unable to validate my results with that of establised ASME and other papers.... Any suggestions? Thanks, |
April 6, 2012, 03:03 |
Hi Hagen,
MRFSimpleFoam should work for your case. Greetings Ivan |
April 10, 2012, 03:38 |
Hagen Müller
Thanks for your suggestion. However, I think that the MRFSimpleFoam solver alone is not sufficient to account for RANS system rotation thoroughly, since not only the solver, i.e. the momentum equation, but also the turbulence model as well as the scalar flux model (if the energy equation needs to be solved) has to be extended. An additional production term due to Coriolis acceleration appears in both the transport equation for Reynolds stress and the scalar transport equation. More details can be found in the paper by Johnston, Halleen and Lezius (JFM 56, pp. 533-557, 1972). An exemplary extension for an explicit scalar flux model can be found in Younis et al. (Journal Heat Transfer, 132, 2010). Last year I implemented both into OpenFOAM on the basis of SSG and LRR. If anyone is interested in the code, you may send me a private message with your email address so I can provide code + documentation.
Best, Hagen |
April 10, 2012, 04:09 |
Mo Ah.
Hi Hagen,
Could I please draw your attention to http://www.cfd-online.com/Forums/fluent/99552-3d-rotating-channel.html#post353897. I've trying to model a 3D rotating channel using FLUENT. I've been unable to match my Nu plots with that of an expermental analysis conducted by Wagner et al 1991. I'm currently using a MRF with a constant angular velocity. Are you suggesting that additional source terms for the body forces induced by coriolis acceleration need to be included even if we are using a MRF?? Regards, |
April 10, 2012, 05:47 |
#6 | |
Hagen Müller
March 20, 2014, 20:52 |
Huang Xianbei
Hi,Hagen:
I'm just struggling in this problem using DNS. I modified the icoFoam by adding the Coriolics force, and the centrifugal force is considered to be coupling with the pressure gradient term, so no specially term is added with centrifugal force. I ran the rotating case with a satisfied non-rotating case as the initial condition yesterday, until now the velocity is still increasing(my computer is too slow) , although the tendency of the Reynolds stress is right , the value is not satisfactory and also the U+ distribution along with y+. So can you please share your code with me? I want to see is there anything ignored.My email is: znhuang@163.com Huang Xianbei |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
rotating channel | emilio | Siemens | 1 | April 6, 2012 00:21 |
Setting up for Rotating 2D straight channel | pkgupta | FLUENT | 0 | April 2, 2010 05:56 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 06:14 |
Rotating channel flow case file? | tstorm | FLUENT | 0 | April 8, 2009 09:40 |
