Compressible flow through a box at low pressure
Old   January 19, 2011, 14:13
Default Compressible flow through a box at low pressure
nbulleid is on a distinguished road
Hi, I'm somewhat new to CFD and openfoam. I was hoping someone could advise me on whether I can run this simulation in openfoam and what the best solver would be.
I want to study the flow of a compressible gas through a box with a simple inlet and outlet arrangement. The problem is that the Knudson number may be as high as 0.04 (the mean free path is not perfectly known). I've been using sonicfoam but I've read that this isn't the best solver to use. Could someone recommend a better one to use in this situation?
nbulleid is offline   Reply With Quote
Old   January 20, 2011, 05:15
Nakul
nakul is on a distinguished road
Hi
Try rhoCentralFoam for compressible calculations. It is a good solver if your fluid follows the basic "continuum assumption" at all times.
nakul is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
low speed compressible flow lily CFX 2 November 16, 2005 05:15
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 13:19
