January 26, 2011, 16:19 |
__LES Questions__
Dear Foamers,
Two questions about LES model: 1- What is U or P in this model. is it filtered one or real one. i mean U and P which are results and be written in folders and their initials which is at 0 folder. 2- It is not a filteration process in oneEqEddy or smagorinsky models but there is available for DynSmagorinsky. Why? http://foam.sourceforge.net/doc/Doxy...agorinsky.html http://foam.sourceforge.net/doc/Doxy...agorinsky.html Thanks in advance, |
January 26, 2011, 22:04 |
my understanding
Charlie
Rep Power: 15 |
1. I think the U and P in the result are real one rather than filtered, filtering process is internal process, and basically we are combing resolved and sub-filtering scale to present the real result.
2. since the smagorinsky and oneEqnEddy model are two-level filtering model, dynSmagorinsky model are three filtering model. To avoid the a possible loss of efficiency of classical Germano-Lilly dynamic procedure, the scale-dependent dynamic procedure is obtained by considering a second test filtering level. please see "Large Eddy Simulation For Incompressible Flow" Third Edition, Page142, by Pierre Sagaut. Above is my shallow understanding of your question, if anything wrong, please let me know, thanks! |
January 27, 2011, 01:56 |
prove it please!
Farshad
Rep Power: 15 |
Hi Foamers,
Thanks for this nice discussions. I appreciate you. please show me where the real U and P are constructed by the filtered one. My poor understanding is because only the LES pointer is selected by runtime mechanism ,only and only the subgrid scale model is written in terms of filtered variables and therefore the overall equation only contains filtered variables. Please correct me if i am wrong. And also the boundary variables should be set after manual filteration! Thanks alot Farshad |
January 27, 2011, 09:34 |
SGS stress
Charlie
Rep Power: 15 |
Nice discussion really! As far as I know, in LES model, the effect of the resolved subfilter-scale (RSFS) and subgrid-scale (SGS) motions on the resolved velocity field must be modeled. The RSFS contribution can be theoretically reconstructed, and the SGS stress must be modeled, in DynSmagorinsky we use Germano-Lilly eddy-viscosity SGS model in which the total parameter C*delta is calculated dynamically. So the solution has filtered and subfiltered components in itself. Again, it's just my understanding on that, please let me know if I'm wrong. |
January 27, 2011, 10:40 |
link to the filter
Charlie
Rep Power: 15 |
since there are many different type of filters, take simpleFilter as an example. you can refer to the following link: http://foam.sourceforge.net/doc/Doxy...8C_source.html |
Display Modes | |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 08:53 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 14:39 |
[Other] Some perhaps stupid questions about calculix | lynx | OpenFOAM Meshing & Mesh Conversion | 11 | May 17, 2010 06:48 |
So many questions in DPM & UDF - Help! URGENT! | Prashanth | FLUENT | 0 | March 3, 2009 22:26 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
