October 3, 2012, 09:46 |
About moveDynamicMesh
Samuele Z
Rep Power: 18 |
Dear Foamers,
I have seen a fantastic feature of Fluent. The mesh motion is possible through an automatice re-meshing. Let's say, for example, that I wanna open a door. I create a single mesh and then launch the simulation and the software first strech the cells and then - when the skewness reaches a certain values - the solver itself do a remeshing. Is there something similar in OF? Or we have only a tool that stretch the mesh? Thanks a lot, Samuele |
October 3, 2012, 10:09 |
Sandeep Menon
Rep Power: 25 |
October 3, 2012, 11:21 |
Samuele Z
Rep Power: 18 |
That's nice.
How does this work? Is it downloadable? Can you help? I can be a good tester .. Thanks, Samuele |
October 3, 2012, 11:26 |
Sandeep Menon
Rep Power: 25 |
The non-parallel bits are already part of OpenFOAM-extend.
With parallel functionality, you'll have to check it out from the repository. Installation instructions are here: https://github.com/smenon/dynamicTop...er/Install.txt I believe Kyle Mooney has already prepared documents / presentations on usage of the class at the recent OpenFOAM workshop, so if you go through the archives, you should find them there. |
October 4, 2012, 04:40 |
Samuele Z
Rep Power: 18 |
Can I share my case in order to understand if someone can help?
How can I do this? |
moveDynamicMesh with dynamicMotionSolverFvMesh | gfilip | OpenFOAM Running, Solving & CFD | 7 | March 19, 2014 05:35 |
moveMesh vs. moveDynamicMesh | samiam1000 | OpenFOAM | 2 | May 31, 2012 10:22 |
moveDynamicMesh | Sylvain | OpenFOAM | 13 | November 10, 2011 23:22 |
moveDynamicMesh in parallel chrashes | Arnoldinho | OpenFOAM Bugs | 18 | May 19, 2011 13:57 |
moveDynamicMesh broken ? | podallaire | OpenFOAM Bugs | 2 | November 11, 2009 13:44 |
