__LES Questions__
Old   January 26, 2011, 16:19
Lightbulb __LES Questions__
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
Two questions about LES model:
1- What is U or P in this model. is it filtered one or real one. i mean U and P which are results and be written in folders and their initials which is at 0 folder.
2- It is not a filteration process in oneEqEddy or smagorinsky models but there is available for DynSmagorinsky. Why?
http://foam.sourceforge.net/doc/Doxy...agorinsky.html
Thanks in advance,
maysmech is offline   Reply With Quote
Old   January 26, 2011, 22:04
Smile my understanding
Charlie
cheng1988sjtu is on a distinguished road
1. I think the U and P in the result are real one rather than filtered, filtering process is internal process, and basically we are combing resolved and sub-filtering scale to present the real result.
2. since the smagorinsky and oneEqnEddy model are two-level filtering model, dynSmagorinsky model are three filtering model. To avoid the a possible loss of efficiency of classical Germano-Lilly dynamic procedure, the scale-dependent dynamic procedure is obtained by considering a second test filtering level. please see "Large Eddy Simulation For Incompressible Flow" Third Edition, Page142, by Pierre Sagaut.
Above is my shallow understanding of your question, if anything wrong, please let me know, thanks!
cheng1988sjtu is offline   Reply With Quote
Old   January 27, 2011, 01:56
Default prove it please!
Farshad
Farshad_Noravesh is on a distinguished road
Hi Foamers,
Thanks for this nice discussions. I appreciate you.
please show me where the real U and P are constructed by the filtered one.
My poor understanding is because only the LES pointer is selected by runtime mechanism ,only and only the subgrid scale model is written in terms of filtered variables and therefore the overall equation only contains filtered variables. Please correct me if i am wrong. And also the boundary variables should be set after manual filteration!
Thanks alot
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   January 27, 2011, 09:34
Default SGS stress
Charlie
Nice discussion really!
As far as I know, in LES model, the effect of the resolved subfilter-scale (RSFS) and subgrid-scale (SGS) motions on the resolved velocity field must be modeled.
The RSFS contribution can be theoretically reconstructed, and the SGS stress must be modeled, in DynSmagorinsky we use Germano-Lilly eddy-viscosity SGS model in which the total parameter C*delta is calculated dynamically.
So the solution has filtered and subfiltered components in itself.
Again, it's just my understanding on that, please let me know if I'm wrong.
Old   January 27, 2011, 09:52
maysmech's Avatar
Thanks for your contributions.
Do you know in which place of OpenFOAM filtering of parameters occured? i need its source file.
Regards.
Old   January 27, 2011, 10:40
Default link to the filter
Charlie
since there are many different type of filters, take simpleFilter as an example. you can refer to the following link:
http://foam.sourceforge.net/doc/Doxy...8C_source.html
possible interview questions atturh Main CFD Forum 1 February 21, 2012 08:53
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 14:39
[Other] Some perhaps stupid questions about calculix lynx OpenFOAM Meshing & Mesh Conversion 11 May 17, 2010 06:48
So many questions in DPM & UDF - Help! URGENT! Prashanth FLUENT 0 March 3, 2009 22:26
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
