Problem with using icoFoam for flow in a straight tube
Old   February 10, 2011, 06:01
Question Problem with using icoFoam for flow in a straight tube
edificelp is on a distinguished road
Hi:
I am trying to use OpenFoam to simulate incompressible, laminar flow of Newtonian fluids in a straight tube. And the 3-d mesh is converted from .msh file of Gmsh. After setting up boundary condition and running the simulation, the courant number mean increases so fast and becomes nearly infinite. Then the simulation stops with the information below:
Courant Number mean: 4.47866e+122 max: 1.17861e+124
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/icoFoam"
#6  __libc_start_main in "/lib/libc.so.6"
[1]+  Done                    kate ~/.bashrc
Floating point exception
The file of this simulation has been attached. Could someone help me solve this problem?
Thanks a lot!
edificelp is offline   Reply With Quote
Old   February 10, 2011, 09:27
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
A blind guess: Try to reduce your time step to suffice the CFL condition.
jhoepken is offline   Reply With Quote
Old   February 10, 2011, 14:07
Jean El-Hajal
Jean El-Hajal is on a distinguished road
it seems your problem came from the fvSolution and fvSchemes file. Replace them with the original ones from the cavity tutorial.
However the mesh is very bad !
Regards,
Jean
Jean El-Hajal is offline   Reply With Quote
Old   February 10, 2011, 17:23
Thanks a lot! After reading user guide, the incompressible steady state flow just can be simulated by simpleFoam. If icoFoam is used with steadyState, the solution will not converge.
By the way, Jean EI-Hajal, could you tell me how do you determine the mesh is bad or not? This mesh is generated by Gmsh automatically with the characteristic length. I feel headache to check this 3-d mesh.........
Old   February 11, 2011, 03:27
Jens Höpken
Run checkMesh and post the output. That tool checks the quality of the mesh and prints some statistics to your console.
analytical solution of 1D shock tube problem ma Main CFD Forum 10 May 11, 2015 05:20
laplacian1%7cAUp is undefined in dictionary problem with icoFoam derath OpenFOAM Pre-Processing 3 June 14, 2013 06:24
problem when running icoFoam on a complex shape flow field wendywu OpenFOAM 1 May 20, 2009 23:40
VOF problem, liquid film thickness Pedro24 FLUENT 0 May 13, 2009 05:57
Shock tube problem ger Main CFD Forum 1 September 24, 2003 07:41
