Rough wall boundary conditions
Old   February 10, 2011, 11:43
Default Rough wall boundary conditions
isa_ is on a distinguished road
I'm a basic OpenFOam user. I've been working on a simulation of a water droplet moving on an inclined surface. Up to now, I've been simulating smooth surfaces with different contact angles. I've been using InterFoam, making the assumption of laminar flow and incompressible fluid. I just had to implement the contact angle in the o/alpha1 file. I now need to model a rough surface. I've read that it is possible only in turbulent flow. I was thinking of using a turbulent model and implementing the nutRoughWallFunction in the 0/nut file. DOes this make sense? DO I need to change something else passing from a laminar to a turbulent model in this particular case? And what's the difference between the nut file and the mut one? Because i read that also a mutRoughWallFunction exists. Is it possible?
I've already tried a couple of simulations but i ended up with a fatal error about "Adjustable delta T" and I'm worried it could be linked to an error in the boundary conditions. is it possible?
Thanks a lot for your help.
isa_ is offline   Reply With Quote
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
Wall boundary conditions for 3d-cylinder Martin Bellmann FLUENT 1 July 11, 2008 13:04
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
