volume flow through internal hole in the wall |
February 1, 2011, 18:37 |
Wouter van der Meer
Rep Power: 17 |
hello all,
I want to calculate the volume flow through a hole in the wall that separates two compartments. The wall is not vertical to the whole so I cannot use the sampe surface, because this is a plain, not a circular part of a plain. Any help is appreciated. Wouter |
February 2, 2011, 02:13 |
Karl-Johan Nogenmyr
Rep Power: 21 |
I've never done it, but I've heard you can split your domain in two. The split should be where you want to measure the flow rate. During run, you then connect the two domains using cyclic boundary conditions. Then you can integrate the flux over one of the cyclic patches.
Else, one would just like to define a (oriented) faceSet and simply integrate flux over them... but the above solution is the only one I've heard of. Kalle |
February 3, 2011, 05:46 |
Wouter van der Meer
Rep Power: 17 |
Thanks Kale for the suggestion. It took me 4 days to get the results, so I am looking for a post processing step to get the volume flow.
Any suggestion? |
February 3, 2011, 06:58 |
Karl-Johan Nogenmyr
Rep Power: 21 |
Hmm... you may try with paraview. Have a look at this one:
http://paraview.org/OnlineHelpCurren...ghSurface.html K |
February 14, 2011, 07:36 |
workaround found
Wouter van der Meer
Rep Power: 17 |
I succeeded in calculating the volumeflow.
For this I used 2 steps: 1) I used the sample utility to calculate a surface 2) in Octave (Mathlab) I limited the surface to the values inside the hole and integrated over this area. thanks |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 04:36 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
internal flow and external flow ? | Pathway0320 | FLUENT | 1 | November 17, 2006 03:37 |
Flow + split volume | Mark | FLUENT | 3 | March 18, 2003 10:09 |
