February 23, 2011, 04:33 |
a question about moving mesh
chenkai
Rep Power: 15 |
Hi everyone,
I want to simulate a braking process of a wheel using OpenFoam. The first step I want do, is to let the wheel rotate with a konstant angular velocity. And then give a electromageneticfield to create a loreze force and stop the wheel. My problem is how can I use the dynamicMeshDict to make the wheel rotate. I have search the information about the rotating mesh on Internet. But most of them are related to turbine, which have two part: a rotor and a stator. And they use the slidingInterface or GGI. But in my case I only have a wheel, so it should be easier than the turbine. Does anyone have idea, how to make a wheel rotate in OpenFOAM? Thanks in advance |
Display Modes | |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Moving Mesh Run problem - Scientific Linux | G. SE | Siemens | 2 | May 7, 2008 07:15 |
Moving (structured) mesh | Jesper | CFX | 5 | February 2, 2007 03:43 |
Moving and deforming mesh | paolo | FLUENT | 0 | June 19, 2003 08:12 |
