February 28, 2011, 06:50 |
janafThermo Error/Calculation script?
Dear Forum,
I'm testing the coalChemistryFoam-Solver on OpenFOAM-1.7. There i got a small case, i.e. a tube with only one Particle of coal, i want to track devolating and combusting. Therefore I'd like to simulate coldflow first. But everytime is start the calculation, i get this errormessage: ========================== Solving chemistry diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 0.9999999999, Final residual = 2.357901633e-07, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 2.475990053e-07, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.867723085e-06, No Iterations 1 DILUPBiCG: Solving for O2, Initial residual = 1, Final residual = 9.395203123e-08, No Iterations 2 DILUPBiCG: Solving for CH4, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for H2, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for hs, Initial residual = 1, Final residual = 3.923674927e-09, No Iterations 2 --> FOAM FATAL ERROR: attempt to use janafThermo<equationOfState> out of temperature range 0 -> 5000; T = -38253.3 From function janafThermo<equationOfState>::checkT(const scalar T) const in file /home/nini/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 63. FOAM aborting #0 Foam::error: :PrintStack(Foam::Ostream&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::specieThermo<Foam::janafThermo<Foam: :PerfectGas> >::Hs(double) const in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #3 Foam::specieThermo<Foam::janafThermo<Foam: :PerfectGas> >::THs(double, double) const in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #4 Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foa m::sutherlandTransport<Foam::specieThermo<Foam::ja nafThermo<Foam: :PerfectGas> > > > >::calculate() in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #5 Foam::hsPsiMixtureThermo<Foam::reactingMixture<Foa m::sutherlandTransport<Foam::specieThermo<Foam::ja nafThermo<Foam: :PerfectGas> > > > >::correct() in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #6 main in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/coalChemistryFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/openfoam/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/coalChemistryFoam" Abgebrochen =============================== So I'm "out of range". My Temperature seems to be not within the borders of 0 -> 5000K. But my T-file is set-up with an internal field of 1300K and zeroGradient at walls/patches. So where could be my error? Setting the calculation/fv-Schemes to Gauss linear uncorrected or limited doesn't seem to gain some success. The code seems to read the "scalar T" (I guess from my T-file?) and compares with the borders - but where can be the fault? With best regards, STefan |
[OpenFOAM.org] OpenFOAM 1.6.x Installer for Ubuntu | Canesin | OpenFOAM Installation | 142 | March 30, 2015 04:58 |
icem script | prad | CFX | 5 | July 23, 2010 16:30 |
Perl script for intialisation | pratik mehta | CFX | 2 | September 10, 2008 03:09 |
awk script question | awk script question | Main CFD Forum | 0 | March 28, 2005 02:06 |
TASCflow,problem with script and parallel mode | Zbynek Hrncir | CFX | 0 | October 2, 2001 07:30 |
