Boundary condition and Poiseuille flow simulation
Old   February 23, 2010, 11:25
Arrow Boundary condition and Poiseuille flow simulation
Cyp
Cyprien
Cyp is on a distinguished road
Hi everybody,
I am new with OpenFOAM. I am trying to solve a 2D Poiseuille flow using the icoFoam solver.
My geometry and meshing are the following :
convertToMeters 0.1;
vertices
(0 0 0)
(1 0 0)
(1 0.1 0)
(0 0.1 0)
(0 0 0.01)
(1 0 0.01)
(1 0.1 0.01)
(0 0.1 0.01)
blocks
hex (0 1 2 3 4 5 6 7) (40 40 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(1 5 6 2)
wall fixedWalls
(3 7 6 2)
(1 5 4 0)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
I apply an inlet and outlet pressure values with the fixedValue boundary condition.
However, I am still looking for the velocity boundary condition type I need to use. Actually, I haven't found the Fluent "velocity outlet" equivalent...
Can you help me ?
Cyp is offline   Reply With Quote
Old   February 25, 2010, 06:53
Tammo Wenterodt
wenterodt is on a distinguished road
What exactly do you mean by Poisseuille-flow? A laminar channel flow? Then you might want to look here:
http://www.cfd-online.com/Forums/ope...utlet-b-c.html
//Tammo
wenterodt is offline   Reply With Quote
Old   February 26, 2010, 03:49
Cyp
Cyprien
Thank you for your answer.
Actually, the BC I looked for was
type pressureInletVelocity;
value uniform (0 0 0);
Old   May 12, 2010, 06:24
Emanuele
nuovodna is on a distinguished road
Can you post your 0/p file?? Thanks in advance
Regards
nuovodna is offline   Reply With Quote
Old   March 10, 2011, 16:28
Default Beginner
albem is on a distinguished road
Can you please post your 0/p file and 0/U file? I am also trying to simulate a 2D Poiseuille flow using the icoFoam solver. But it is not clear to me which boundary should I use for the U and p?
Thanks
albem is offline   Reply With Quote
Old   March 10, 2011, 16:36
Sorry I forgot to mention I am using Version: 1.7.1
thanks in advance
Alberto
Old   March 11, 2011, 14:53
I have tried to include the previous recommendations for the 2D Poiseuille flow and this was the result using icoFoam
Time = 0.5
Courant Number mean: nan max: nan
DILUPBiCG: Solving for Ux: solution singularity
DILUPBiCG: Solving for Uy: solution singularity
DICPCG: Solving for p: solution singularity
time step continuity errors : sum local = nan, global = nan, cumulative = nan
ExecutionTime = 2.3 s ClockTime = 3 s
End
This is my /0/U file
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
value uniform (1 0 0);
outlet
fixedWalls
type fixedValue;
frontAndBack
type empty;
boundary condition, poiseuille flow, simulation
Poiseuille flow Kirikou Main CFD Forum 0 November 23, 2006 13:32
Simple Poiseuille flow Maggie CFX 0 May 27, 2004 10:58
Flow in duct Jackie CFX 1 July 26, 2003 09:15
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 16:52
Wall BC in LES woodward Main CFD Forum 10 August 21, 2002 10:01
