March 15, 2011, 09:08 |
Problems about tutorial files
Streamlet
Rep Power: 15 |
Deal All
I am a greenhand of OpenFOAM, so I want to learn how to operate it from the tutorial files. But the user guide does not povide any detail information about the tutorial cases expect the cavity and interFoam cases. I am confouse about other examples and want to know what the other examples talk about. So is there any documents for describing the detail information about other examples? Many thanks! |
March 15, 2011, 12:14 |
Petar Zivkovic
Rep Power: 15 |
I think you should download and print entire user guide...that was my first taught also...that the documentation is not so great, but if you read entire manual you'll see how things will be clearer over time and constant work with OF.
Here is link where you can download entire User Guide: http://foam.sourceforge.net/doc/Guides-a4/UserGuide.pdf All best! P.Z. |
March 15, 2011, 19:26 |
Streamlet
Rep Power: 15 |
Thank you very much, I will follow your instruction.
March 16, 2011, 06:38 |
Robertas N.
Rep Power: 17 |
The problem is that most of the more advanced tutorials are completely undocumented. There is no explicit info about that setup is being simulated and why, how are the models selected, where is the data (e.g., termochemistry data) taken from, what do most of the nontrivial input parameters mean. From my experience, the most useful resources are the PhD theses http://www.foamcfd.org/resources/theses.html and Chalmers university courses http://openfoamwiki.net/index.php/Handy_links (item 4 as of time of writing). Even though they do not mention specific tutorials (sometimes they do), some relations between descriptions in the theses and tutorial implementations can be traced.
Tutorial for subcooled nucleate boiling | Asghari | FLUENT | 42 | December 10, 2018 11:42 |
Problems of running Oscillating plate tutorial | vovogoal | CFX | 20 | February 4, 2016 07:03 |
Problems with CCL (loading .res files) | Tobias | CFX | 2 | September 15, 2010 03:06 |
Please help I need Fluent 6 tutorial mesh and case files... | bbcorrozojr | FLUENT | 2 | May 7, 2009 04:38 |
