April 5, 2011, 03:24 |
openfoam-1.7-extend. when?
Raimonds Vilums
Is there a plan to release 1.7-ext version in near future?
April 6, 2011, 09:24 |
Hrvoje Jasak
Rep Power: 33 |
Yes There is a few things to wrap up, contributions have been collected and the main obstacle is doing the final phase without driving me to lunacy... Is there anything in particular you are missing?
I will keep you posted, Hrv
April 7, 2011, 09:35 |
Raimonds Vilums
Actually, no. Probably, what I will need, is in 1.6-ext already. I would say: because I start to get into the code right now, I prefer to use the latest version.
My current investigation is not so difficult in general: heat transfer with heat source in connected solids. The problem - I use transient coefficients everywhere. I made Robin BC on the surface with groovyBC; physical coefficients I defined as fields and approximated as polynomials. Current questions for me right now is: a) how better to treat connected solids, i.e., how correctly implement temperature-dependent conjugation (transmission) conditions. Before, I used setFields to set different values of physical properties, I used "harmonic" approximation of conductivity in laplacian but the results was worse than for "linear". As far as I know as mathematician, linear approximation, theoretically, leads to other solution than original. Not so big trouble with simple mathematical problems, but I still care for my future projects b) how to implement BC with the second order of approximation c) in distant future: how to implement flow of direct electrical current in metal with Joule heating. Quick search did not gave me awareness if this is already implemented or available. |
LowRe-SST in OpenFOAM 1.7? | Peter85 | OpenFOAM Running, Solving & CFD | 17 | February 24, 2015 20:03 |
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 04:29 |
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results | Arnoldinho | OpenFOAM Community Contributions | 7 | December 9, 2010 16:29 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 | alberto | OpenFOAM | 12 | July 28, 2010 11:59 |
