sonicTurbDyMEngineFoam
Like Tree1Likes
  • 1 Post By Peter_600
Old   January 29, 2013, 03:23
Default Opening soon the exhaust valve "sonicTurbDyMEngineFoam"
Sasan Ghomi
sasanghomi is on a distinguished road
Hi every body,
I have a problem with a case for coldFlow in an internal combustion engine (sonicTurbDyMEngineFoam )....the exhaust valve opens early (about 0.005 (s) ).Can any one help me????
How do I correct it???
thanks,
Sasan
sasanghomi is offline   Reply With Quote
Old   January 29, 2013, 04:35
Retired Super Moderator
Bruno Santos
Greetings Sasan,
Can you please provide more information? The reason I ask is because you're not providing enough information, as indicated in this thread: http://www.cfd-online.com/Forums/ope...-get-help.html
Best regards,
Bruno
PS: don't mind about the other post with strange characters, it was just a spammer...
Old   January 29, 2013, 06:16
Sasan Ghomi
Hi wyldckat ,
Thank you very much.
I am running a case that it simulates the cold flow in an internal combustion engine.
The solver is sonicTurbDyMEngineFoam.The rotational velocity is (rpm=1500), So the total time for a cycle of the engine is 0.08(s).I expect that the exhaust valve opens at 0.06(s)
but when I plot the mass flow versus time at the exhaust port I saw that the exhaust valve opened at 0.055(s).How do I can correct this problem???please any one help me....
The engineGeometry is as below :
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      engineGeometry;
conRodLength    conRodLength [0 1 0 0 0 0 0] 0.147;
bore            bore [0 1 0 0 0 0 0] 0.092;
stroke          stroke [0 1 0 0 0 0 0] 0.075;
clearance       clearance [0 1 0 0 0 0 0] 0.015;
rpm             rpm [0 0 -1 0 0 0 0] 1500;
engineTopoChangerMesh  simpleEngineTopoFvMesh;
// Between -deformAngle and deformAngle the piston motion is done
// using deformation and not layering
deformAngle     10;
valvePosTol     1e-4;
layeredMesh     yes;
checkMesh       yes;
piston
    patch               piston;
    coordinateSystem
        type            cartesian;
        origin          (0 0 0);
        axis            (0 0 1);
        direction       (0 1 0);
    minLayer        0.0005;
    maxLayer        0.001;
valveSplitPoint     (0.003 0 0);    // For the converter
// Two-valve engine valves are split on x
// Four valve engines are split into 4 quadrants in the x-y plane
valves
    intakeValve
        // Valve coordinate system
        coordinateSystem
            type            cylindrical;
            origin          (-0.025 0 0);
            axis            (0 0 1);
            direction       (0 1 0);
        // Patch  and zone names
        bottomPatch             valve1;
        poppetPatch             valve2;
        stemPatch               valveStem1;
        curtainInPortPatch      valveCurtainPort1;
        curtainInCylinderPatch  valveCurtainCyl1;
        detachInCylinderPatch   valveDetachCyl1;
        detachInPortPatch       valveDetachPort1;
        detachFaces
2593
2595
2597
2599
2601
2603
2605
2607
2609
2611
2613
2615
2617
2619
2621
2623
2625
2627
2629
2630
        // Vertex on edge of the step.  For the converter
        stemEdge            (-0.04 0 -0.0075);
        // Valve diameter
        diameter            0.03;
        // Minimum valve lift
        minLift             0.00025;
        // Layer thickness
        minTopLayer         0.0005;
        maxTopLayer         0.001;
        minBottomLayer      0.0005;
        maxBottomLayer      0.001;
        // Lift Profile
        liftProfileFile "intakeLiftProfileFile";
    exhaustValve
        coordinateSystem
            type            cylindrical;
            origin          (0.025 0 0);
            axis            (0 0 1);
            direction       (0 1 0);
        bottomPatch             valve3;
        poppetPatch             valve4;
        stemPatch               valveStem2;
        curtainInPortPatch      valveCurtainPort2;
        curtainInCylinderPatch  valveCurtainCyl2;
        detachInCylinderPatch   valveDetachCyl2;
        detachInPortPatch       valveDetachPort2;
        detachFaces
4854
4856
4858
4860
4862
4864
4866
4868
4870
4872
4874
4876
4878
4880
4882
4884
4886
4888
4890
4891
        stemEdge           (0.04 0 -0.0075);
        // Valve diameter
        diameter            0.03;
        minLift             0.00025;
        // Layer thickness
        minTopLayer         0.0005;
        maxTopLayer         0.001;
        // Lift Profile
        liftProfileFile "exhaustLiftProfileFile";
An image of the case is attached.
Thanks,
Sasan.
Old   January 29, 2013, 08:18
Peter_600 is on a distinguished road
The exhaust will open when the lift exhaust valve lift exceeds 0.0025 as specified in your dictionary.
So it depends on your valve lift profile.
cheers peter
sasanghomi likes this.
Peter_600 is offline   Reply With Quote
Old   January 29, 2013, 08:39
Sasan Ghomi
Thanks for your reply peter,
Can you give me any sources about describtion of minimum valve lift and valve lift profile??
Can you explain them??
thanks,
Sasan.
sasanghomi@yahoo.com
Old   October 4, 2016, 20:11
EngineJob
enginejob is on a distinguished road
hi, i have a problem with this solver too. The error is:
 --> FOAM FATAL ERROR:
found boundary face in valve detach definition for valve 1.  This is not allowed.  Detach faces:
24
12316
12317
12318
12319
12320
12321
12322
12323
12324
12325
12326
12327
12328
12329
12330
12331
12332
12333
12334
12335
12336
12337
12338
12339
 nInternalFaces: 12190
    From function void simpleEngineTopoFvMesh::addZonesAndModifiers()
    in file simpleEngineTopoFvMesh/addSimpleEngineTopoFvMeshModifiers.C at line 188.
Searching for this function i have found it:
// Create a detach zone
            if
                valves_[valveI].detachInCylinderPatchID().active()
             && valves_[valveI].detachInPortPatchID().active()
             && valves_[valveI].detachFaces().size() > 0
                Info<< "Adding detach boundary for valve "
                    << valveI + 1 << endl;
                const vectorField& areas = Sf().internalField();
                const labelList& df = valves_[valveI].detachFaces();
                boolList flip(df.size(), false);
                const vector& pistonAxis = piston().cs().axis();
                forAll (df, dfI)
                    if (isInternalFace(df[dfI]))
                        if ((areas[df[dfI]] & pistonAxis) > 0)
                            flip[dfI] = true;
                    else
                        FatalErrorIn
                            "void simpleEngineTopoFvMesh::"
                            "addZonesAndModifiers()"
                        )   << "found boundary face in valve detach definition"
                            << " for valve " << valveI + 1
                            << ".  This is not allowed.  Detach faces: "
                            << df << " nInternalFaces: " << nInternalFaces()
                            << abort(FatalError);
probably i have some problems with the mesh, right ?
How do i do the mesh at the detach zone ?
enginejob is offline   Reply With Quote
