May 10, 2011, 15:06 |
heat transfer w/o turbulence
AV.
Rep Power: 15 |
hello all,
I'm new using openfoam.. I need help to choose a solver to heat transfer channel but without turbulence or radiation... which solver should i choose for my case? Can i use buoyantPimpleFoam without turbulence ? Thanks! |
May 12, 2011, 12:21 |
Freeman Adane
Rep Power: 16 |
of cause...! For any of the solvers, can be used to run laminar flow, I pressumed is your case by simply using "laminar" and "off" for RASModel and and "turbulence", respectively in "RASProperties" file.
May 12, 2011, 13:20 |
AV.
Rep Power: 15 |
Thanks !
I'll try it ! |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
Conjugate heat transfer problem | hvem10 | FLUENT | 2 | October 29, 2009 17:31 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
heat transfer in two-phase flow | Leonid Fromzel | CFX | 0 | April 8, 2008 05:57 |
