April 21, 2011, 02:52 |
problem with paraView
Rep Power: 15 |
sometimes after I solved a case I can't watch the result because the solved case looks like in the picture below. (Normally there are colored surfaces) Is there a mistake in the step of solving or in the step of paraviewing? Best Regards, tH3f0rC3 |
April 21, 2011, 03:07 |
Kurne
Rep Power: 15 |
Hi
If the geometry is complex then the outline is came in the browser, this is due to complex geometry only what i experience. If there is any reason then i dont know it.
Simulation Is Determination Of Imagination Towards Approximation ® Best Regards Mubeen K Kurne |
April 21, 2011, 06:20 |
Rep Power: 15 |
Ok, the complex geometry can be a reason. But I can view the same model solved with chtMultiRegionSimpleFoam. |
April 21, 2011, 06:39 |
#4 | |
Tobias Holzmann
Rep Power: 51 |
Hi Dirk, you have to put the "outline" to - > "surface" then you got your display. If the mesh and geometry is large (size), paraview uses the Outlines as a standard preferences. Tobi |
April 21, 2011, 06:52 |
Rep Power: 15 |
That's it!
Thank you! :-) tH3f0rC3 |
Display Modes | |
Problem with Paraview | ata | OpenFOAM | 10 | August 6, 2011 04:21 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 19:13 |
problem with new OF170 paraview instalation | anmartin | OpenFOAM Installation | 3 | June 29, 2010 19:29 |
Yet another Paraview problem | gascortado | OpenFOAM | 5 | February 21, 2010 07:39 |
[OpenFOAM] Problem with Colors in ParaView | sven | ParaView | 1 | May 31, 2009 09:13 |
