Implementation of Two Inlets in a Mixing Problem
Old   April 15, 2011, 13:12
Cool Implementation of Two Inlets in a Mixing Problem
Fatemeh
fpmhadi is on a distinguished road
Hi everybody,
I am trying to implement a mixing layer case in OpenFOAM.
My geometry is a square with two inlets, one in left hand side and one in right hand side and of course two outlets opposite to inlets in left and right. Upper and lower walls are fixedWalls. I have attached my mesh.
I edited 0/p and 0/U as follows:
0/p:
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
fixedWalls
type zeroGradient;
frontAndBack
type empty;
0/U:
boundaryField
inlet
type fixedValue;
value uniform (1 0 0);
outlet
type zeroGradient;
fixedWalls
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
But, I know that there is something wrong in 0/U, because must assign different values for velocity U in right and left patches. The problem is that I do not know how to do it.
Would you please help me through it?
Thank you,
fpmhadi
File Type: png Screen shot 2011-04-15 at 1.09.59 PM.png (16.2 KB, 18 views)
fpmhadi is offline   Reply With Quote
Old   April 15, 2011, 13:49
Martin
MartinB will become famous soon enough
Hi fpmhadi,
you must name your inlets differently, like: "inlet_left" and "inlet_right". Then you can assign individual vectors for U.
The patch definition with the new names must be done in your blockMeshDict, too.
Martin
MartinB is offline   Reply With Quote
Old   April 15, 2011, 14:55
Fatemeh
Hi Martin,
Thank you very much.
I tried to name the inlets differently, but it did not work, because I did not know the correct syntax.
I edited blockMeshDict, 0/p and 0/U as follows:
blockMeshDict:
patches
patch inlet_right
(5 11 9 3)
patch inlet_left
(0 6 8 2)
0/p:
boundaryField
inlet_right
type zeroGradient;
inlet_left
type zeroGradient;
0/U:
boundaryField
inlet_right
type fixedValue;
value uniform (-1 0 0);
inlet_left
type fixedValue;
I really appreciate your instructions.
fpmhadi
Mixing occuring faster than the experiment problem Lila Main CFD Forum 1 September 5, 2007 10:48
Cross-Shaped Mixing Park, Jaehong FLUENT 0 March 10, 2004 23:07
Validation of shear mixing layer using kwsst Samuell FLUENT 0 September 9, 2003 22:46
Validation of shear mixing layer using kwsst Samuell FLUENT 0 September 9, 2003 22:27
Mixing time problem Rai FLUENT 1 January 15, 2003 03:43
