foamToTecplot
Old   April 17, 2011, 11:57
Default foamToTecplot
Pramod Rao
pramodrao1984 is on a distinguished road
Hi friends,
I have been using ubuntu 1.7.1 from few months and have also installed tecplot360. I have issues now with tool Tecplot.
After running the solver, when I try to convert foam results to tecplot data using command foamToTecplot, I recieve error "foamToTecplot : command not found" ,
I really need to sort out this error, .........is this because I have to install git repository for 1.7.1.. ? (as I read in one forum..not sure)
if so please let me know how....
since I am new to OF n tecplot.... please help me
thanks in advance,
Pramod
pramodrao1984 is offline   Reply With Quote
Old   April 18, 2011, 10:23
ya
rujia is on a distinguished road
hi
I think the command line is foamToTecplot360, try again and good luck.
rujia is offline   Reply With Quote
Old   April 18, 2011, 11:03
Pramod Rao
Originally Posted by rujia View Post
hi
Thanks rujia,
it is working.... can you guide me as to how to access *.plt file in tecplot360 (command needed to open *plt in tecplot360 tool), generated by command foamToTecplot360
Old   April 18, 2011, 14:10
taxalian is on a distinguished road
Send a message via Skype™ to taxalian
hi
you need to import first the grid file i guess contained in your 0/ folder and then also import the rest of the files using multiple file option in tecplot.
taxalian is offline   Reply With Quote
Old   April 18, 2011, 14:15
Pramod Rao
Originally Posted by taxalian View Post
hi
Thanks Taxalian,
I will check it out and come back to with the feedback..
Old   April 19, 2011, 05:18
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
See also http://openfoamwiki.net/index.php/Tecplot
akidess is offline   Reply With Quote
foamtotecplot
It would be wonderful if a tool for FoamToTecplot is available luckyluke OpenFOAM Post-Processing 165 November 27, 2012 06:54
foamToTecplot problems titio OpenFOAM Post-Processing 0 July 22, 2010 14:32
Problem manipulating Data in Tecplot after foamToTecplot Conversion titio OpenFOAM Post-Processing 2 June 10, 2010 04:23
Tecplot problem nzy102 OpenFOAM Post-Processing 1 April 16, 2008 05:26
[OpenFOAM] How to plot a contour of a zcoordinate on a surface sek ParaView 3 August 30, 2007 16:58
